Old 06-07-2016, 06:22 PM   #11
Liked 1,953 Times in 439 Posts
Default Re: closed vs open loop
Take a plastic hammer (or small ball peen) and tap lightly but firmly on components such as ECM, MAF sensor, coils, module(s), relays, etc.
Check grounds and harness connections everywhere.
Also tap on and otherwise shake or vibrate the battery.
Old 06-07-2016, 08:05 PM   #12
Ed Wright
Ed Wright's Avatar
GM recomends the "slap test", at least on my last trip to the GM Training center. May recomend mallets now, but I would be surprised.
Ed Wright 4156 SS/JA
Old 06-07-2016, 10:40 PM   #13
The slap test works okay, on the ECM. The right hammer tap (and no, I'm not advocating beating it to death) will often expose a lot of components that have an internal fault, due to cracked boards, bad solder joints, loose pin fit, and various other "intermittents", especially those that show up on rough road, or under various sharp maneuvers.
Old 06-11-2016, 05:28 PM   #14
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
I was working on a Ford a few years ago which was acting the same, the DPFE valve would short and loose the 5V reference to the other sensors, causing it to stall. No codes either. Unplug it and try.
Patric Fox is offline   Reply With Quote
