Old 01-27-2016, 11:46 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Hot Rod class question
I'm not an IHRA member but I'm thinking about running HR at Capitol and/or MIR this year. What will it cost for a newbie to run? Do I need something more than a membership, license and HR number? How tough is the tech inspection?
Ron Gusack is offline   Reply With Quote
Old 01-28-2016, 09:03 AM   #2
cal
cal's Avatar
Liked 31 Times in 18 Posts
Send a message via AIM to cal
Default Re: Hot Rod class question
Hello and welcome to the fun.
You will need to become a IHRA member, and get a HR #. If your car runs faster then 135MPH you will need a Lic, no physical required. Tech is pretty standard.
Come on and play.
Cal S/ST HR 1177
cal is offline   Reply With Quote
Old 01-28-2016, 09:38 AM   #3
Robbie Welch
Liked 262 Times in 124 Posts
Ron welcome, as Cal said member ship & H/R number. The 135 mph thing is NHRA I believe. Min weight 2600lbs. All your safety stuff needs to be up to date helmet 2010 snell number min. Depending on how fast your car is you may need a throttle stop and a delay box if you run a trans brake. Your car will need sfi harmonic balancer, sfi flex plate & shield, and a sfi trans shield. But all these you should already have if you run 10.90 or quicker hope this helps.
Old 01-28-2016, 11:59 AM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Snell 2005 should also be accepted this year.
S/ST 51
S/C 53
Old 01-28-2016, 01:55 PM   #5
Ron Gusack
Ron Gusack's Avatar
Thanks for the replies. I'm good on all the safety stuff except for the flex plate shield. I didn't know it was a requirement in Hot Rod. The dates on the trans shield, balancer, and flexplate have passed. Do they check those dates?
Old 01-28-2016, 02:00 PM   #6
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
No shield needed if stock firewall
Ken MacNicol is offline   Reply With Quote
Old 01-28-2016, 05:44 PM   #7
Rick Blake
Rick Blake's Avatar
Ron.....Please run a diaper even if it's not a requirement.
Rick Blake
Rick Blake 2395 SG, SC, SP
Rick Blake is offline   Reply With Quote
Old 01-28-2016, 09:27 PM   #8
Shake & Bake
Liked 37 Times in 33 Posts
Snell 2005 is accepted thru 2016. Will have to step up to a Snell 2010 in 2017.....
Shake & Bake is offline   Reply With Quote
Old 01-28-2016, 10:34 PM   #9
Ron Gusack
Ron Gusack's Avatar
I have a diaper and the helmet is 2010. The window net doesn't have any sfi label cause it's from 1981. I guess it's time to update that. The rule book says a competition license is required in Hot Rod.
Old 01-29-2016, 07:06 AM   #10
Keith 944
Keith 944's Avatar
If it's a ribbon net you're fine no sfi needed if it's the Mesh style it has to have a date they changed that rule a few years back and what they mean by license is basically paying for your competition number
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
