Old 11-27-2015, 03:26 PM   #21
Dave Gantz
Liked 251 Times in 125 Posts
Default Re: 79 Mustang project U/SA
I haven't done it myself, but have read about it on Thecorral.net. It sounds like it's a b**** on a Fox. Maybe search over there to see if someone has a good method?
Old 11-28-2015, 08:26 AM   #22
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Thanks Mark and BS 428. I didn't realize that it's that easy to get the car under weight. I think I will leave them for last. I'm in strip it down mode and figured i'd pull them out too. I weigh 165 so making it light might be easier than I thought.
Mark, thanks for the help too. I for sure will call you as i progress in the project so I don't make any costly mistakes.
Old 11-28-2015, 12:09 PM   #23
mopacltd
Liked 124 Times in 44 Posts
Robbie, you know you will be racing that fast Maverick in the Graham stable.
mopacltd is offline   Reply With Quote
Old 11-28-2015, 01:07 PM   #24
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Remove unneeded wiring, all sound deadener, carpet insulation, and anything not needed. You will be surprised what that adds up to. It's all in the details, and adds up quickly. Get the weight off the front so you can put it where you need it in the back. Find an aluminum front bumper.
There is mastic that glues the door skin to the crash bars, so don't just start prying and pulling on it, otherwise you will do a number on the door skin. My 78 Zephyr, the crash bar had to be cut in half to get it out of the doors A cut-off wheel is best, and whatever you do protect/remove the glass or you will be replacing it. The grinding embers will pit the glass.
Sean Marconette
84 Mustang
5060 SS/N
Old 11-28-2015, 03:25 PM   #25
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Drop one of the factory seats on a scale and compare the difference with a racing seat. Whole bunch right there.
If you come heads up to Brian Seaburg's U/SA Comet at a Lucas Oil Series race, get up on the wheel.
Dale
Dale Shearon
68 Mustang 6394
Old 11-28-2015, 07:14 PM   #26
Wink Re: 79 Mustang project U/SA
Sean, Probably not much left on any 79 Arizona car.
Old 11-28-2015, 09:07 PM   #27
Sean Marconette
Is that due to the heat Mark?
Sean Marconette
84 Mustang
5060 SS/N
Old 11-28-2015, 10:33 PM   #28
SSGT Mustang
Liked 204 Times in 54 Posts
I recently removed the door braces on my son's Mustang. They weigh about 30 lbs together. The doors in the early fox bodies have large braces in them. The ones from about 90 on have much smaller bars.
Each bar had to be cut in three places. One cut in the middle and a cut on each end. The only tool that worked for me was a cut off tool. I used both a small straight cutter and 90 degree cutter to get it done. I was going to try a plasma cutter but it just didn't seem like a good idea.
I put an 1/8" thick, 8" X 8" sheet of of aluminum between the bar and the door skin where I made the cuts in order to avoid hitting the door skin. Once you see the aluminum stop cutting.
You need to remove just about everything in the door to make the cuts and get the bars out. It's a pretty big job but well worth it. The doors close so much easier and the weight can be moved to a better location.
Use long sleeves and wear gloves.
SSGT Mustang is offline   Reply With Quote
Old 11-28-2015, 11:36 PM   #29
Yes. I don't remember the bars being stuck to the skin on my 80 turbo car (79).
Now that I think about it , I probably used the slice and dice method on it.
Yes, it was a SOB
Just left a little bit of a tab on the ends.I didn't want to get into the jambs on that style door.
The above described method works better on the 2nd Gen Firebirds and Camaros
Old 11-29-2015, 12:43 PM   #30
RobbieRacer
Mark, I look toward to racing BJ. She is a cool lady. Seeburg is a badass. I hope to get my car as fast as theirs. I'll take my time and get it right the first time.
