Old 02-10-2015, 07:36 PM   #21
jmracing
jmracing's Avatar
Default Re: Hydraulic Rollers
JMRACING
Go with Comp Cams # 15850-16the best one for the price
jmracing is offline   Reply With Quote
Old 02-10-2015, 09:50 PM   #22
Rob Petrie E395
Liked 216 Times in 77 Posts
I sent Chris at Comp a email and did not expect to hear back till tomorrow but he was able to get back to me tonight.
For those interested here is what he said about the 2 different lifters.
For a race engine the 15850-16 is best for a race application because it only has .030" of travel and it can take over 500#'s of open spring pressure.
The 875-16 has about .100" of travel and can take 400#'s open pressure.
Old 02-10-2015, 10:32 PM   #23
JRyan
Liked 112 Times in 31 Posts
Jeff,
You can only run your '88 as a 138 HP engine with the .921" lifters. I'm sure there is great deal of latitude taken with the "Aftermarket OEM-type lifters permitted" statement by those who like to stretch the rules, but I was told when building our 138 HP Cutlass Stocker, that I had to use the "big" lifter, so we did.
Fortunately, they're able to be shimmed for limited travel, and unfortunately, they're heavy and require the 138HP roller block.
Jerry
Old 02-15-2015, 03:31 AM   #24
Andy G
Liked 8 Times in 2 Posts
When checking the NHRA engine specs for the 1987, 307/138 olds I see that the diameter for these roller lifters is .698".
Is there an advantage to the smaller diameter lifter? I would think that that the larger diameter would be more stable in the bore at higher RPM. The smaller diameter would be lighter. Is the diameter a factor in choosing the better lifter for stock eliminator?
Andy G is offline   Reply With Quote
