Old 01-06-2015, 01:27 PM   #1
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Default Reactor Flexplate Beware of this manufacturer !!!!
Idk of how many times I've had to post of manufacturing companies that run a business this bad but i hope to just inform some before they make the same mistake i did. It was supposed to be a simple purchase of a basic Pontiac flexplate . It has now turned into a 4 month return of the product 4 times just to get the correct bolt pattern and hole size from a guy who apparently thinks I'm to perfect to ask for this to be right .
Please save yourself from dealing with this Olen character that runs this F up operation.
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 01-06-2015, 01:31 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Reactor Flexplate Beware of this manufacturer !!!!
ATI & TCI don't have them?
Ed Wright 4156 SS/JA
Old 01-06-2015, 04:05 PM   #3
SSDiv6
The best place to get the correct Reactor flexplate is from Coan racing transmissions.
Old 01-06-2015, 04:06 PM   #4
Ed Wright
Ed Wright's Avatar
What is different about it? (Reactor)
Old 01-06-2015, 04:20 PM   #5
Rich67stang
Liked 116 Times in 27 Posts
Reactor flexplates are Aluminum, I have had good luck for 10 years with them until
this past season and blew one in half @ 10k rpm. They should be changed very frequently. I went to a Meziere steel.
Richard Preiser
1613 FGT/I 1510 C/SA 161 F/DA
Rich67stang is offline   Reply With Quote
Old 01-06-2015, 05:11 PM   #6
SSDiv6
I believe you got your money's worth using it for 10 years @ 10K RPM!
Old 01-06-2015, 05:15 PM   #7
SSDiv6
Ed, like Rich said, they are Aluminum.
Being they are Aluminum, they also help in the dampening of frequencies htroughout the RPM range. They work the best on high RPM engines such as 4 and 6 cylinder engines.
Nevertheless, although a great product, the company has its issues with delivery and also their customer service is not the best. Therefore the reason why I recommend procuring the flexplate from Coan since most of the times he has them in stock.
Old 01-06-2015, 08:08 PM   #8
Ed Wright
Ed Wright's Avatar
Don't guess I need one. :-)
Old 01-06-2015, 08:41 PM   #9
Don't think that would be a problem with a Pontiac.
Old 01-06-2015, 09:01 PM   #10
SSDiv6
I should help dampen the frequencies of that heavy, big stroke crankshaft.
