Hi guys, just for my own curiosity, what camshaft does the 65 425 h.p.
396 use? I know that the big Chevy, the Vette, and the Z16 were rated at 425 h.p. For some reason I thought they used a hyd. camshaft. Also, how does the 65 396 Vette fit A / Stock? Like i stated I am just curious. Thanks in advance, Alan jr. |
#2 | |
Bill Seabrooks - superfan1 Bridgeport, CT |
#3 | |
Banned
Liked 235 Times in 110 Posts
Liked 800 Times in 237 Posts
Alan, the '65 396-425's (Corvette and full size Chevys) had a mechanical lifter camshaft with .497/.503 lift. This was a different camshaft than the '66 and later 396-375's and 427-425's (.520/.520).
The '65 396/375 was only available in the Z16 Chevelle. That motor was virtually the same as the '65 396-425's with the exception that it used a hydraulic cam (.461/.500). Most people assume the '65 396-375 Z16 is an L78, which it isn't. It's actually an L37. Hope this helps. -Al
"That'll never work....." |
Liked 1,059 Times in 376 Posts
What was the difference between the 1st design and 2nd design L-88 camshafts...I had that 1st design in a 427/425.69 RS Z-28( street car)
.To this day, I prefer the rattle of that old motor over any other camshafts....I'm sure different grinds made more power, but that thing sounded nasty....
Jeff Niceswanger 3740 SS |
#6 | |
#7 | |
Liked 783 Times in 195 Posts
Also, the hydraulic camshaft used in the 396-375 Z16 Chevelle is the same camshaft used in the 396-350/360 hp engines and 427-385/390/400 hp engines in 1966-1969, again with slightly different clerical numbers. |
#8 | |
Bob Gipson made that case with NHRA and they stick with the lower lift cam. That is what he has in his 65 vette A/Stick. Fun car and it is for sale.
James Schaechter 3163 STK |
Liked 55 Times in 28 Posts
I agree that the first design L88 cam had a great sound. I can't get to my chevy power books right now but they showed the profiles, etc. iirc, it was about 264 deg. at .050" and rated duration was around 360 deg.
