Old 05-16-2014, 06:03 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Air Ride MH problems
I have 98 HR on freightliner chassis. The front air bags are very slow to inflate and seem to be low pressure. Is there a pressure regulator in the air bag system? Ride height valves seem to be ok. can someone point me in the right direction?
Mike Graham
Mike Graham is offline   Reply With Quote
Old 06-04-2014, 10:04 AM   #2
Chuck Westcott
Chuck Westcott's Avatar
Default Re: Air Ride MH problems
In the 90's many MH builders used a Norgren ride height valve to control air in and air out to beach of the Air bags, Mine went bad and I replaced it. there are 2 relay solenoids one on each side. Mine was located in the front up in the frame rail, I have a picture if you need it.
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 06-04-2014, 10:46 AM   #3
Mike Graham
Thanks Chuck. I will check that out.
