#11 | |
Liked 1,607 Times in 584 Posts
Also understand that the SS Modified classes use Comp Eliminator engines with non-billet cylinder heads. |
#12 |
I know canted/splayed valve heads are allowed but it doesn't mean they're better
#13 |
Liked 783 Times in 195 Posts
#14 |
One of the fastest AM cars has/had wedge heads
#15 |
Liked 880 Times in 311 Posts
Karl,
I read the rules a couple of times and saw what I thought was the answer to your question. Since all classes are presented in the rulebook in an orderly "Building" sequence. The later builds on the first. I was just about to say the Stock and SS aftermarket heads would be allowed because they were allowed in classes before the SS/AM category. That is the way it usually happens, but in this case they are not allowed because one line in the SS/Modified rules projects what heads can be used. The wording says "must be OE head with OE casting number". The answer is NO. I know this is not the answer you were looking for. To make sure I contacted one of my super secret NHRA Tech mentors and I got this answer to the query. NO. So don't show up with an Edelbrock Head in SS/Modified. Guess that closes the door on anything but a factory part number head.
Adger Smith (Former SS) |
#16 |
Liked 237 Times in 126 Posts
I just finished splitting the 2014 rule book into sections and found that Super Stock, Super Stock GT and GT Truck all follow the cylinder head guidelines for SS. Beginning with the Modified groupings, these change, as do a lot of the other overall regs for the cars like full cages required in all machines. Specifically no aluminum heads.
Read Cylinder Heads under SS and compare it to Cylinder Heads under Modified Stock. Dale
#17 |
Dale,
That is what I mean about the rules building on one another, until there is a change in the next class. If you notice when you go from SS to SS GT the wording at the beginning of the GT it will say that GT forllows the SS rules with the exception of the following and go into the GT changed rules. So when it goes into modified it changes the head rules, like you said. Like my NHRA source said when I followed up with a phone call. Read the rules. They say nothing but a Factory part number head. Just my own thought, but If he wants a Ford with an alum head I think there are several available, but not FE's. My buddy RJ told me one time he had some iron FE's that were better than the Edelbrock Fe's, but that was in Stock. Hey, follow the rules. Do some iron heads on the FE and come out and play.
#18 |
It makes no sense you cant run an aluminum copy of a factory head but you can use a canted valve SBC head which resembles nothing close to a production head.
What about IHRA? Super Stock production classes? |
#19 |
Liked 5 Times in 2 Posts
The Mopar heads are, those P5 motors are quite nasty.
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
#20 |
Quote from Karl: It makes no sense you cant run an aluminum copy of a factory head but you can use a canted valve SBC head which resembles nothing close to a production head.
What about IHRA? Super Stock production classes? It is all about the factory part number. If Ford had assigned a factory part number to them they would be legal. That is what makes sense... You need to have a conversation with Mike Baker @ IHRA about the FE Ebelbrock head. He's the IHRA man!!
Adger Smith (Former SS) Last edited by Adger Smith; 02-07-2014 at 09:59 AM. Reason: sp |
