#21 |
Liked 286 Times in 73 Posts
All you need is a boiler and a radiant starting line!
#22 |
Liked 293 Times in 65 Posts
#23 |
Guest
Posts: n/a
We were in Alaska for Christmas visiting the grandchildren and I checked the DA app on my phone (I do that too much when I'm not at the race track) and at one point I saw it was -5200'. I got a little sad that the race car was 4000 miles away ... and oh yeah, that it was -18 degrees with 2' of snow on the ground.
Scott |
#24 |
DA app on your phone? What kind of phone?
What's it called?
Ed Wright 4156 SS/JA |
#25 | ||
Liked 13 Times in 9 Posts
GT/HA. I did notice it's not listed in Nitro Joe's Stats, probably just because the passes I made in Mike Volkman's rent-a-ride in the same class were faster than the ones in my car. I went 10.369 at the Maple Grove LODRS. http://www.dragracecentral.com/DRCSt...r2013#indextop
You can make a starting line hook with little problem. Downtrack is more of a challenge as it just doesn't maintain the heat and the groove can disappear. Piedmont has a track *heater*. ![]()
#26 |
Liked 216 Times in 77 Posts
#27 |
Guest
Posts: n/a
We have Androids and it's called Density Altitude Calculator IIRC. It was free. I just went to the Play Store and typed in density altitude calculator and several came up. Picks up the weather and elevation from the nearest local airport. I've checked it with the online drag times one and it's pretty close.
Scott |
#28 | |
I'll have to see if there is a DA app for an iPhone. Thanks guys!!
#29 |
Liked 2 Times in 1 Post
I have Race IQ for iphone. The DA calculator on it is fairly close. I mainly use it for logging runs, comparing runs, and helping to figure the dial in. I like it because you can compare any part of the runs. It breaks it down pretty well.
Derek
Derek Hake 4459 H/SA 69' Roadrunner |
#30 | |
![]() Thanks, unfortunately the Gators turned into just a test session for us, so we were all kind of in a bad mood that race as it's not how we wanted to start out the season. Usually we are all very approachable, so you definitely caught us at a bad time. ![]() |
