#101 |
Liked 10 Times in 7 Posts
I find it interesting that alot of us get on planes everyday that are 20 years or older (and private planes even older) with belts that are deemed comepletely safe by FAA but NHRA makes us change every 2 years.
#102 |
The Boeing 777 has an inspection interval of 12000 hours of operation for seat belts. This is only an inspection, not replacement. It is subjective; you inspect the belts and if they look, appear worn or frayed, or the mechanism does not work, then they are replaced.
#103 | |
Liked 3,227 Times in 981 Posts
All that said, it's their rules so if you want to play on their sandlot then it is what it is.
#104 |
NHRA is simply requiring repeat business for companies in return for their sponsorship, right?
Ed Wright 4156 SS/JA |
#105 |
#106 |
You didn't get the change of topic memo? LOL
Doug Blackley 1697 STK |
#107 |
Liked 30 Times in 17 Posts
Biggest safety advance they could make would be to roll back 40 years and institute the Big Daddy rules package (I.e.starts at the end of a run or you are disqualified).
Sorry, I am only in my early fifties. What does this "starts at the end of a run" mean? |
#108 |
Big advocated a rules package that included at the end of a run the fuel cars should be able to restart and run. If they couldn't they would be disqualified. He had a well thought out proposal to control cost and improve the racing but guys like Bernstein advocated the go fast approach that requires mega sponsorship $$$ to field a car. The DSR/JFR circus is the result.....
#109 |
Liked 308 Times in 103 Posts
means that car would have to be able to start and run at end of track,nitro cars.
Big Daddy thought it would be good,cut back on oil downs and keep guys from leaning on stuff so hard they blew up every pass. Mike Taylor 3601 I type way too slow Last edited by Mike Taylor 3601; 05-22-2013 at 08:13 AM. Reason: addition |
#110 |
Liked 162 Times in 45 Posts
Maybe another magneto and a bigger fuel pump would help you're typing speed! Lol
