Liked 101 Times in 27 Posts
OK lets hear what you got. I have all the numbers for a stick car which is my intent BUT if I have to go automatic weapon 3 speed-----anyone care to suggest a gear ratio for a 327/274 Chevy ll stocker---3005 lbs---30" tire----three speed metric auto ???? I would love to get it right the first time. THANKS for any intelligent replys.
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Liked 308 Times in 103 Posts
MPH X Gear ratio X 336 divided by tire height = RPM.
You'll have to allow for converter slippage someone else could tell you more on that # but probaly 5-8% would be good guess as example figures crossing @ 7100 add 8% would be 7668 Stick car will match formula almost exactly. Can also figure converter % slippage@ top end w/this formula as close as can for guys without data recorder Mike Taylor 3601 |
#3 | |
Liked 99 Times in 49 Posts
Liked 684 Times in 289 Posts
I run 5:13 in my wagon (350/2bbl/Glide) in P/SA @ 3850 lbs or so
Its got a 28.5 Goodyear ( I forget the roll out) One friend runs (350/4bbl/Metric200) 69 Camaro in G/SA uses 5:13 with 30.0 ( Hoosier, I think) Another friend 350/2bbl 69 Camaro M/Stick uses 5:13 with 30.0 M/T Don`t have roll out #`s for those Most people I talk to that run SBC Stockers run 5:13`s Just my two cents Good luck Last edited by Mike Jones; 03-06-2014 at 09:40 AM. Reason: add info |
Liked 69 Times in 32 Posts
Twist the spine outta the old girl!!!
Ron Mattson 5015 STK |
![]() Last edited by Mike Jones; 02-22-2014 at 12:20 AM. Reason: info |
Liked 209 Times in 46 Posts
Might be better off with a GOOD powerglide
Liked 121 Times in 11 Posts
I am inclined to agree with Mr. Lewis. Car is really light and in testing not much difference but consistency.
Joe DeMarzo 1317 STK |
#9 | |
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
