#41 | |
Liked 100 Times in 45 Posts
Former NHRA #1945 Former IHRA #1945 T/SA |
#42 |
Liked 56 Times in 21 Posts
ed
why not you can't buy a mustang or a dp from the dealer i think that would be cool and a 289 snake
Vic Guilmino 1129 STK |
#43 |
Liked 5 Times in 2 Posts
I was referring to current stock legal darts/barracudas to be allowed to convert over to a hemi and run in one of the new classes since the weight breaks are for super stock only.
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
#44 |
Liked 653 Times in 89 Posts
Vic
If you are having trouble getting new CJ cars or parts Just call VARSITY Ford Ann Arbor Michigan. just ask for Joe in parts he can get you any CJ part or you can place an order a 2013 CJ Open 6 days a week.
Charley Downing 3548 STK |
#45 | |
Liked 2,362 Times in 559 Posts
#46 |
Liked 320 Times in 102 Posts
Looks prety simple to me..........
The cylinder head rules in Stock didn't change and that states "The following are permitted: polylocks, jam nuts, screw-in larger-diameter rocker studs or pinned studs, bronzewall valve guides" The ONLY rule that chaged was the ability to use aftermarket rocker arms and they did NOT have to be (as the old rule was) "Aftermarket rocker arm must be identical to OEM. Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both. OEM roller rockers permitted ONLY if application was originally equipped with roller rockers" The difference is now the rule says "Aftermarket rocker arm permitted. Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both. Looks like stud mounted roller rocker arms for the OEM stud mounted engines and T&D's for the OEM shaft type rocker arms. I don't like the rule but is seems pretty clear on what their intention was.
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 11-22-2011 at 04:12 PM. Reason: aluminum center section on OEM only |
#47 | |
Liked 536 Times in 110 Posts
Jim Kaekel 3836 STK |
#48 | |
Liked 165 Times in 54 Posts
ok why is this happening??? So i guess before to long the jackets, neck braces, and gloves will have to be renewed?
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#49 |
Paired shafts, like the Harland Sharp offerings, or stud mount conversions.
Alan Roehrich 212A G/S |
#50 | |
You mention stud conversions for a small Ford 5.0. IMO, that would take machining the head to accept a stud and milling the pedestal to accept a guide plate, correct?? That would be a no no as I am told............am I wrong and lots of racers have done this and that makes it ok? I would love to go to a screw in stud and a guide plate and toss the dumb azz shims kits in the trash. |
