Liked 19 Times in 2 Posts
Should be interesting.
Mike Ficacci Stk 1010 Last edited by MikeFicacci; 11-21-2011 at 06:40 PM. |
Liked 276 Times in 54 Posts
SECTION 10A: STOCK CARS, ENGINE: 1, ROCKER ARMS (Page 5)
Aftermarket rocker arm permitted. Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both. Can we get a translation on this please. |
Liked 21 Times in 7 Posts
AAA/SA? ... CC/SA? ... would it have been that difficult to just reorder the classes from A on down?
Liked 33 Times in 17 Posts
OK, roller rockers are allowed. ANY ratio allowed?
#5 | |
Liked 3,232 Times in 983 Posts
The camera/video rights section caught my attention, as well as substance abuse policy now being more in line with what most employees working for a company already abide by. Stock still 1955 or newer to put that BS to bed. http://www.nhra.com/UserFiles/file/2...Amendments.pdf
#6 | |
Chad Rhodes 2113 I/SA |
Liked 451 Times in 77 Posts
5.5 lb Super Stock class…
I found nothing in there about diapers or belly pans on Super Stock cars... |
Liked 189 Times in 48 Posts
Shuhhsh - don't give em any ideas !
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
I have it on good authority that the rule will be amended again soon. As it is now, they did not even specify stock ratio or stock configuration. As open as it is right now, by the letter, we could go out and buy a set of Jesel or T&D shaft mounts in whatever ratio we wanted. After all, they bolt to a stock head.
![]() Of course, NHRA would say "just because we did not tell you that you cannot, does not mean that you can". ![]() I guess it is kind of cool, though. If your Stock Eliminator combination is factored at 500HP, you can run AAA/S at 3170 with driver, on a 9" slick.
Alan Roehrich 212A G/S |
Liked 231 Times in 107 Posts
Who will be the first 8 second stocker?
