Old 10-01-2010, 02:32 PM   #31
Myron Piatek
Liked 138 Times in 51 Posts
Default Re: 2011 Dodge Challenger V10 Drag Pak
Originally Posted by Dgal View Post
Thanks for posting the pictures. That is a very good looking car. I like the hood better than the 2010 Drag Paks.
There are a couple of things that I noticed. I didn't see a factory weight box, but that shouldn't be a problem. It doesn't appear to have much set back to the engine. That may be due to it being a V10. I would be a little concerned about getting it to hook if it makes power like the other combos have been on 9" tires.
Don
Power? maybe. But the v-10 Viper engine is ALL aluminum! But I don't know what it weighs compared to a new Hemi or conventional Mopar small block.
Old 10-01-2010, 03:02 PM   #32
Gordie Kissner
Liked 18 Times in 10 Posts
Originally Posted by Jeff Teuton View Post
Should be an a/sa or aa/sa car as well as super stock. We got one of those in a viper body already. Ran 9.20 @ 148. Course the glide will slow it down. I guess all you Chevrolet guys can go crazy now. Why don't you use your energy to solicit Chevrolet to get in the game and then yall would not have to complain. Problem solved. And Chad, 425 is too high. Who knows it might be a turkey.
Hey Jeff, any chance these will be offered in street trim off the showroom floor?? Awesome car!
Gordie Kissner
SS 6010
STK 6010
Gordie Kissner is offline   Reply With Quote
Old 10-01-2010, 03:24 PM   #33
dwydendorf
dwydendorf's Avatar
Liked 19 Times in 7 Posts
Rumor has it that there is a supercharged version and a n/a version and one is light enough with the aluminum block to still fit in A/SA .
ss/gt 93 t-bird
dwydendorf is offline   Reply With Quote
Old 10-01-2010, 03:54 PM   #34
FINESPLINE
FINESPLINE's Avatar
That is some combination ! Is everybody assuming that the trans is a powerglide or is this a mopar one off trans ? Best reason I can think of for offering the 2 speed is to make it easier to hook with small tires ( 9 in.) ! Would it be a retroactive trans to the 2009- 2010 Drag Paks ? Cannot even begin to ponder the the ratings on this motor ! GONNA BE AN INTERESTING WINTER .
FINESPLINE is offline   Reply With Quote
Old 10-01-2010, 04:06 PM   #35
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Originally Posted by Wade_Owens View Post
THAT is not funny......
Wade O
Hey Wade, I know you will give them a good fight ......................lol
Bob Bender 144 O/SA
Old 10-01-2010, 04:36 PM   #36
Stocker 449
Stocker 449's Avatar
Good thing they will probably be classified in something like G or H....... My max wedge is becoming more and more obsolete as the days go by!
Michael Colaluca
449 A/SA
Stocker 449 is offline   Reply With Quote
Old 10-01-2010, 05:02 PM   #37
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Good point, Michael. Jeff doesn't seem to realize that most of us are not wealthy or own a dealership. It doesn't matter about the brand. All older stockers are being hurt by the new bogus cars.
You run a mopar, I run a chevy, RJ runs a ford. Who cares about the brand. A loss is a loss no matter if it's a chevy beating a chevy or a mopar beating a chevy.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 10-01-2010, 05:21 PM   #38
Hokes Racing
This is what a 2010 viper has
With a 1mm bore increase over the previous generation engine, the new 8.4-liter (510 cubic inch) A356 T6 aluminum block 90 degree V10 motor now achieves 600 horsepower at 6,000 rpm and 560 lb-ft of torque at 5,100 rpm. An assembled steel articulating CamInCam® camshaft, that allows variable exhaust valve timing, along with the new VENOM engine controller, with massive processing power, provides the necessary technology to achieve these very high output levels and still meet idle and OBD requirements. Other new features for the V10 include: - New cylinder heads with larger valves, CNC chambers and throats - Flat top piston with 10.2:1 compression ratio - Race tested swinging oil pickup from the Dodge Viper Competition Coupe - Dual electronic throttle bodies (ETC) - Low restriction induction system with dual mass airflow control (MAF) - Air-gap headers and low restriction exhaust system - Individual high energy coils for each cylinder - Platinum tip spa
Hokes Racing is offline   Reply With Quote
Old 10-01-2010, 05:31 PM   #39
Paul Sarvas
Liked 177 Times in 103 Posts
Smile Re: 2011 Dodge Challenger V10 Drag Pak
Lanny you're a bowtie guy... Viper??
pS
Paul Sarvas is offline   Reply With Quote
Old 10-01-2010, 05:32 PM   #40
Jeff Lee
Jeff Lee's Avatar
The newest Viper has a 640 or 650 HP option above the standard 600 HP. Basically headers, cat-back and air filter mods. Wild-***-guess I would say these V-10 will be at least 850 HP as delivered. And we haven't even seen what the compression and cam specs are. There's probably some CNC heads on the horizon as well.
I know Mopar tried submitting a V-10 to NHRA previously and NHRA was not interested. My, what a difference a day makes!
Jeff Lee 7494 D/S '70 AMX
