Where can you buy a fuel tester like NHRA uses for gasoline ?
Liked 334 Times in 181 Posts
760-375-2398-phone
ridgecrest.ca.us--website Precision Fuel Testing Systems---company Model FT-K01----part number ONE THOUSAND BUCKS $$$$$$$$$$$$$$ plus any accessories make sure you test on a NON metal counter and not within 12 inches of metal walls counters etc-----polypropolene container only !!!! probe fully immersed!!! rock probe back and forth to remove any air bubbles in probe!!!!!! FAILURE to do any of the above will give you a false reading |
Thanks for the info !!
I didn't think it'd be cheap.........BUT WOW !! http://www.ridgenet.net/~hideseng/g-01.htm |
Don't forget you will also need some Cyclohexane to go with the tester.
Dave Ley NHRA TECH |
#5 | |
GASOLINE TEST KIT: Designed for the competitor who wants to assure the legality of his gasoline, this kit provides a sturdy carrying case for your fuel tester with all the items needed to test your own gasoline. The Gasoline Test Kit includes: • Fuel Test Stand • 150ml sample cups (4) • 500 ml DoT bottle for cyclohexane sample • Fuel siphon. • Safety Items, includes glasses & gloves. • Elegant aluminum carrying case which houses and protects all of the above items and the fuel tester. |
Liked 3 Times in 1 Post
How would you know its calibrated correctly? I have been in the fuel trailer when the tech guy comes in there "setting" the meter. Is this an every race day or weekend occurance? If the fuel companies' specs are the same every time, why recal the meter?
Wade |
I believe the cyclohexene is used for calibration.......from what I read.
Liked 1,108 Times in 304 Posts
And don`t forget that you would also need the specs for the fuel being tested, as well as temperature conversion chart that shows the different readings for a given temp.
Liked 67 Times in 19 Posts
my friend that i do the Mopars at the Strip event has a brand new tester only used once and its the same one NHRA uses, if interested, e-mail me and I'll give you him e-mail and phone number. I might bring it home with me in march after the race to try to sell it around here for him.
He has the Cyclohexane to go with it also |
