Old 09-16-2009, 04:51 PM   #1
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
Question Records at a IHRA Divisional
Can records be set at an IHRA divisional???
Thanks,
Bob Lasko
Old 09-16-2009, 05:24 PM   #2
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
Default Re: Records at a IHRA Divisional
yes you can set records there.
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 09-16-2009, 06:15 PM   #3
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
In D-4 they want you to show up torn down. Then they check everything seal you up and then you make the record runs. Backwards from NHRA. Ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 09-16-2009, 06:30 PM   #4
George Mirza
Bob,
If you planned on setting a record this weekend at Epping, I understand they had tear down last Thursday before the national event and then sealed the motors after they passed tech. Our best guess is that the important tech people aren't going to be there. I don't know who to call to check on this, but I'm sure an IHRA regular can post the contact you need.
George Mirza is offline   Reply With Quote
Old 09-16-2009, 06:47 PM   #5
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Records at a IHRA Divisional
Originally Posted by George Mirza View Post
Bob,
Hank Blankenship stayed up there all week . if you come in on friday torn down he will be able to check you and you can be sealed at that point. He has three or four he is doing that i know of for sure. Hope this helps.
Old 09-16-2009, 06:54 PM   #6
Bob Lasko
Bob Lasko's Avatar
I have a modifed motor. don't they just pump the motor???
Old 09-17-2009, 06:12 AM   #7
buzzinhalfdozen
Liked 11 Times in 8 Posts
Bob, yes should be pump only. however you need to be there first day of event to be pumped. last year they didn't want to pump mine on sat. so i could set the record. However they finally agreed to do so, guess they cut the number of guys working the event so they have no time for tech on Sat.-Sun. Joe
Joe Buchanan SS/BX 3117
Old 09-17-2009, 06:13 AM   #8
Marc Kinton
Bob, check your pm's. hope this helps
Marc Kinton is offline   Reply With Quote
Old 09-17-2009, 06:34 AM   #9
Mark Callanan
Liked 64 Times in 14 Posts
You know now that you said that there did seem to be alot less workers this year..
And alot of new IHRA workers this year also....
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 09-17-2009, 08:40 AM   #10
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
they did tear downs before the national lask week. my modified was only pumped and given a quick look-over. i was told that they may have time to do a few cars on friday before the div. but he wasn,t sure if they would have enough staff on hand at that time.
Mark Markow is offline   Reply With Quote
