Old 06-04-2009, 08:54 PM   #11
Jesse Knapp
Default Re: The Keir Stocker is absolutely 1st rate craftsmanship - but is it legal?
Go to Drag Race Central, then the photo column, then click on 100 latest, scroll down to SREPA 1-3. Look for Adam Keir ST. Hope mine looks half as nice. A beautiful car.
Jesse Knapp 4899 STK, SS
Jesse Knapp is offline   Reply With Quote
Old 06-05-2009, 06:43 PM   #12
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
this one??
ID:	870   Click image for larger version
Old 06-05-2009, 06:57 PM   #13
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
To me, unless you have seen the actual car, thru YOUR own eyes, not pictures, or put YOUR hands on a car, you dont have the sac to use your real name, you dont have a counting opinion on wether a car is leagl or not.
To get on the net and basically call someone out, without the above, is useless and a waste of time and bandwidth.
It's beautuiful car, and looks , by the picture, a very well built piece. Props to them ! The car , builders and the performance, evidently.
2894 STK
Old 06-05-2009, 09:32 PM   #14
bill dedman
Liked 6 Times in 4 Posts
His eighth-mile qualifying time converts to a 9.95 quarter-mile e.t.; not bad for an A/SA car the second time out...
Bill
bill dedman is offline   Reply With Quote
Old 06-05-2009, 09:38 PM   #15
fredjohnston
Liked 55 Times in 14 Posts
more like 10.25
fredjohnston is offline   Reply With Quote
Old 06-05-2009, 11:37 PM   #16
Gary Smith
Gary Smith's Avatar
Liked 132 Times in 30 Posts
1. Motor Plate Is it a genuine plate or just a large bracket?
2. Motor / Mounts moved back How was this determined? Did tech measure it?
3. Radiator core support cut to allow front end removal How about NHRA ruling x-member mod for pan removal? That opens up a bigger can of worms. If the mod has no weight distribution or performance gain and is disguised, it's a moot point
4. No stock wiring Show me one that does
5. No heater controls My console and HVAC controls have been removed for trans maintenance and has passed NHRA tech
6. Frame connected above the floor Again, is it blatant or disguised?
7. Incorrect seats If true I agree. Not in the spirit of the category
8. Incorrect steering column Again, I might agree, except was it fab'd or from another body type?
9. A-Frame adjustable stops Now this I can see bitching and protesting, unless he ain't setting the world on fire.
I'm being more curious than pretentious. If visible mods are clearly stated as "prohibited" in the rule book it's a sure bet it won't pass. But Like Herb says, the "stock" in these cars went out a long time ago. I'll tell you there's at least 60 things about my car that aren't "stock" but it's all legal. Class car prep is, at best, like being an illusionist. My guess is you're a stock racer, and assume you already know and understand my reasoning. If not, you miss the whole idea behind class racing.
Gary Smith
"another broke racer spectating"
Gary Smith is offline   Reply With Quote
Old 06-06-2009, 01:08 AM   #17
bill dedman
Fred Johnston has commented that the qualifying time of Adam Kier's A/SA car was not, in fact the equivalent of a 9.95, but more like a 10.25.
Here is his qualifying time for the eighth-mile:
5 1470 A/SA Adam Keir, , '70 Nova 6.471
I don't know how to extrapolate that time to a quarter-mile equivalent, so what I did was to go to National Dragster's INDEX page and find an eighth-mile index as close as I could to the 6.471 Adam turned.
The eighth-mile index for SS/A just happens to be 6.47. Close enough, wouldn't you say?
The quarter-mile index (for that class) is 9.95.
I couldn't do any better than that. If that's wrong, I don't know why.
HOWEVER, the online computer I use, said this:
"Your 1/4 Mile ET is 10.22 seconds computed from your vehicle 1/8th ET of 6.471 seconds."
So, Fred may be a lot closer than NHRA is.........
Go figure....
Bill
Bill
Old 06-06-2009, 03:11 AM   #18
herbjr
Liked 83 Times in 32 Posts
Who is this guy that started this thread. Someone has to know
herbjr is offline   Reply With Quote
Old 06-06-2009, 08:41 AM   #19
Question Re: The Keir Stocker is absolutely 1st rate craftsmanship - but is it legal?
# 3 -- Radiator core support cut -- I have no idea if his is cut or not but I was told last year by D-1 tech officials that cutting the rad supports was a no-no.....................This rule started back in the day of '57 Chevies and has been that way since -- no exceptions ! ! !
Old 06-06-2009, 08:55 AM   #20
Dan Bennett
Liked 602 Times in 138 Posts
I hadn't thought about those old Chevies for a long time until you brought it up, and now I'm trying to remember why we needed to cut the support in the first place.
Was it so you could do a cam change with the engine in the car?
Dan Bennett is online now   Reply With Quote
