Old 05-21-2009, 08:52 AM   #11
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Need help finding my (grimlin)
Probably the biggest problem I've seen on alot of cars is guys seem to run the idle very lean, the manifold MUST be full of fuel vapors or you will certainly have a stumble on quick throttle application. I'm not sure you can put a big enough squirter in it to overcome this issue. Look at it this way when you jab the throttle fuel comes out the squirters at the top of the carb, how long do you think it takes that fuel to reach the cyls? It's not instant hence your hesitation, you need that manifold rich with fuel to have the necc. responce to throttle angle change. Joe
Joe Buchanan SS/BX 3117
Old 05-22-2009, 07:15 AM   #12
Adger Smith
Liked 880 Times in 311 Posts
I have had customers that had problems similar. It happens after the car/boat sits without much use. Check to see if the needles below the squirters are stuck. More common a problem with alky & race fuel than with pump gas.
Adger Smith (Former SS)
Old 05-22-2009, 10:41 PM   #13
jmarkaudio
Originally Posted by Chris Williams View Post
Had a nearly identical problem this past weekend (although on a Dominator). Did three things, and it went away -- unfortunately not sure which one was the solution. What I did: a) put in somewhat bigger idle air bleeds, b) put in bigger accelerator pump squirters, and c) asked the driver to roll into it rather than stomp it. Problem solved.
If it is a 3 circuit Dominator take out the intermediate bleeds and try it. It may surprise you. If it helps I can point you to a cure.
As far as the original post, make sure you check the cap, rotor, wires, etc... other things can cause your issue. Excessive plug gaps can put a high load on the ignition system especially with the newer Digital ignitions. I melted an HEI cap center terminal with a Digital 7.
jmarkaudio is offline   Reply With Quote
Old 05-23-2009, 08:26 AM   #14
Chris Williams
Chris Williams's Avatar
Ummm... I said "problem solved". But, gee, thanks?
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
