Old 04-07-2009, 06:34 PM   #31
Craig Couris
Banned
Default Re: Blown, injected, 4-valve CJ's at Ennis...
Jim,
I'll keep you posted.
Craig
Craig Couris is offline   Reply With Quote
Old 04-07-2009, 06:56 PM   #32
hadtobethere
Talking Re: Blown, injected, 4-valve CJ's at Ennis...
just curious.......I would hope someone would post when they get a heads race with one of these, as I want to know.........QUESTION ???
Your heads up, you cut a great light , have them by a full tenth at 660', do they make a 'whistling' sound when they blow by you?
hadtobethere is offline   Reply With Quote
Old 04-07-2009, 07:35 PM   #33
Bruce Noland
Liked 444 Times in 145 Posts
Originally Posted by A/SA Fairlane View Post
I'm curious what the Moroso calculator says for DeArmonds 9.71 @134.24 record or Ponds 9.68 @138.79 record ?
A/SA,
I'm not sure that Moroso can offer much help for those numbers because they were set at a heavily factored track. But, lets give it a try. What did the cars weigh when they set the records? Not what you think they weighed. The actual weights please.
Bruce Noland 1788 STK
Old 04-07-2009, 09:51 PM   #34
A/SA Fairlane
Liked 57 Times in 19 Posts
I have no idea of their weights on the record runs as I live on the east coast The camaro should be 3400ish if he can get to minimum. I also don't know if the Ford was running the 2 x 4 combo or 1 x 4 combo ? I was just curiious is all.
A/SA Fairlane is offline   Reply With Quote
Old 04-07-2009, 10:49 PM   #35
K Stubbs
Liked 20 Times in 3 Posts
I think Fords idea behind this was to produce a car that you could run stock, superstock, AND super gas all at the same race, driving it off the showroom floor.............. Nice job Ford.
K Stubbs is offline   Reply With Quote
Old 04-08-2009, 01:07 AM   #36
bill dedman
Liked 6 Times in 4 Posts
Yeah, Kevin; just don't forget to disable the active throttle stop when you're through running Super Gas.... lol!
Bill
bill dedman is offline   Reply With Quote
Old 04-08-2009, 05:35 AM   #37
bsa633
Banned
I'm curious what the Moroso calculator says for DeArmonds 9.71 @134.24?
The fomula i been using for a long,long time says 625...comparing dyno sessions and et's it have showed it a little conservative...so it's probably closer to 640-650 ...that is 134+ on the score board and minimum weight ofcourse..
bsa633 is offline   Reply With Quote
Old 04-08-2009, 07:25 AM   #38
John Kelley
Thumbs down Re: Blown, injected, 4-valve CJ's at Ennis...
Originally Posted by clutch man View Post
where these records set at a bogus track that has a reputation of being a fast track?
What is a "BOGUS" track ???
Is a track "BOGUS" because it happens to have GOOD AIR ???
I shouldn't reply to someone with a BOGUS name...... :-(
John Kelley is offline   Reply With Quote
Old 04-08-2009, 11:08 AM   #39
Chad Rhodes
no, a bogus track is one where they subtract .4 from your ET and give you the record for it, even if the actual DA is sea level at the time
Chad Rhodes 2113 I/SA
Old 04-08-2009, 11:28 AM   #40
As a point of reference Erich Bollman ( AA/SA '08 Mustang CJ ) qualfied # 16 at Atco -(remember, this is 1/8 mile) - 6.162 -.868 under . Also he went Top Speed of the event @111.86 MPH .I have no idea what his weight was on those runs .Carry on ..............
