#21 |
Billy -- I think the only rule that applies is the one listed in the rulebook under Section 4.2 of the General Regulations that says 500lbs.is the maximum amount of permanent ballast allowed .Some readers of this thread are doing some wishful thinking that will never apply .
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
#22 |
Sorry Jack, I won't bite on that one. Unless I see a revision to the rulebook then I've got to say that it should be applied as written. The heading doesn't say "Class Suggestions" or "Class Interpretations" it says "Class Requirements". A requirement of a car running A/SA is that it weigh from 8.00 lbs. per HP to 8.49 lbs. per HP.
#23 |
Billy -- Show me otherwise and make a believer out of me ...........if you enforced the rules as you want I'd bet at least 25 to 35 % of any Stocker field would be "pitched" ...........
OK-- that may be a little high but you get it ! ! !
#24 |
Liked 131 Times in 24 Posts
This is what happens in D-2 you can not be heavier than the min. weight of the next lower class. You get a warning during time runs and if you dont remove it for elim. you get DQed. This is FACT boys I was told this by Jim C. and watched it happen.
#25 | ||
Liked 13 Times in 9 Posts
![]() In the interest of full disclosure, I've done it too. The point is, I should *not* have been allowed to do it.
#26 |
Denny-- If what you're saying is correct -- that makes Billy wrong by as much as several hundred lbs.
Michael -- At least you had the "kahonas" to admit you've done it.........
#27 | |
Liked 5,142 Times in 1,963 Posts
A car with a stock gas tank can carry another 120 lbs or 20, depending on preference. Still legal to burn up fuel, isn't it? What about spare tires/ That's another 50-60. Still legal ,as far as I know. Somebody better get to work changing the rulebook, rather than making it up as they go along.
#28 |
Billy -Not hijack your thread but I did a little checking in my "archives" and found that you were right about the '77 Seville not being in the books for more than thirty years -- I couldn't tell when it was added but as of 1988 in wasn't in the Official NHRA Classification Guide..........and here I thought you were looking at it even then ! ! But if you wanted to look the '75 Honda Civic was in along with the Hudson Hornet...........
#29 |
Liked 83 Times in 32 Posts
I have some books from 91,Ill check it tomorrow.
#30 |
Liked 100 Times in 45 Posts
Jennie Craig????????????????????????????????????????
Ed F.
Former NHRA #1945 Former IHRA #1945 T/SA |
