#21 |
Liked 7,863 Times in 1,750 Posts
Jack, OK 25 HP in one shot instead of 2 or 3 shots. 225 lbs will slow your LS-1 down what? 1.8 tenths? Your still 1.22 under. You aren't getting any sympathy here pal.
Art, I still remember being there on that day and I don't remember you getting any sympathy from Jack but t hen you were in one of those oddball, slow cars and not an LS-1 Firebird. Chad, something like that might wirk but lower the trigger to -1.35.
#22 |
Chad's idea is really like what we have in comp-the amount of the adjustment depends on how far under a car runs-this strikes me what people are or should be looking for in adjusting soft combos. The only argument is the increments, say 1.400-1.429 = 3.55; 1.43-1.459 = 5%, well you get the idea, and that's why he added or 1% for every .01. You guys know stock really well and you ought to bring it either the SRAC or get the attention of tech people at NHRA. I'm still optimistic enough to think that if they'd be willing to change something if they can say it's what the racers wanted.
#23 |
#24 |
You can make the trigger/penalty anything you want. The majority of the racers will just adjust to keep under it. Instead worrying about one guy and an odd ball combo you should be looking at the guys who make all their runs at -1.00 under and then get in the cic race and are going -1.25 - 1.40 under. Leaving the event with no run to make a trigger for the AHFS.
The AHFS is doomed to fail because the only incentive for going fast is that you will get HP. If the top 5 qualifiers got paid like the winner and R/U the current rules would have everything sorted out pretty quick. That sounds just as crazy as the AHFS. |
#25 |
Liked 41 Times in 9 Posts
No disrespect meant to anyone, but instead of looking at it like "a 5% hit is 200 lbs or so" how about you just MOVE TO THE HIGHER CLASS!!! Then the only weight you need to move around are those little letters on your window!
Another deep thought brought to you by Zippy! Oh and hi Billy.
Mike Meier "World's most expensive DF/S" 2007 Chevy Cobalt....because suffering through owning an AMC Stocker wasn't enough |
#26 |
Liked 83 Times in 20 Posts
Art Leong, I think you are right. When someone runs a number at an altitude factured track that run should be counted. Another thing should be also considered: When a racer makes a 140 + run, how does anyone know if he/she is legal. That is really unfail to the rest of the folks running that combination. I often thought what if someone was running an illegal combination was cheating or any combination. Then they ran it out the back door and it went 140 under. We all know it would get H.P. on Monday. The worst part it was an illegal engine and hurt everyone with that combination. That car should be torn down to make sure the car is legal before to getting H.P. If the car is found to be legal, than he/she gets the record.
John Duzac D/S 4448 STK |
#27 | |
Chad Rhodes 2113 I/SA |
#28 |
Liked 13 Times in 9 Posts
There have been years of data compiled. Take all the data, do run completion on 1000' times, and compare everything to a -1.00 under baseline, and adjust *everybody's* HP once now, and be done with it. A ton of work once, and then just fine adjustments after that. How long has it taken to get HP factors even somewhat in line on some combinations using the AHFS? While people didn't like the politics of the pre-AHFS days, at least common sense *could* be applied.
#29 |
Dave, you've seen my fingers! They're kind of like these blunt objects sticking out of my hands and the I is right next to the O.
#30 |
Billy -- Its starting to sound like you're making this personal -- its not -- at least for me -- I don't want sympathy from anyone ...........let alone you my friend .
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
