Old 04-03-2024, 04:20 PM   #1
bpete
Liked 19 Times in 4 Posts
Default Ss gt/ta-d
If I understand the Class Racer Info site correctly...
A 91-93 Ranger can run in SS GT/TA through D depending on engine combo.
Is this is a possibility?
Brad
bpete is offline   Reply With Quote
Old 04-03-2024, 06:18 PM   #2
1299
Liked 53 Times in 11 Posts
Default Re: Ss GT/TA-D
You are correct. They did away with the 250lb + or - a few years back in GT
1299 is online now   Reply With Quote
Old 04-03-2024, 09:29 PM   #3
John Winslow Jr
Liked 408 Times in 87 Posts
Not sure I have seen a ford ranger in the GT class, that would be cool, hope you can make it happen. John
John Winslow Jr is offline   Reply With Quote
Old 04-04-2024, 10:26 AM   #4
bpete
I need to look into it a bit further.
I have a donor chassis.
Some of the aluminum replacement heads look like they are not available for some combinations.
Acceptable cross-member modifications are also of a concern. IE what can be trimmed and or replaced within the class guidelines..
Brad
Old 04-05-2024, 09:20 AM   #5
Hacksaw
Liked 309 Times in 173 Posts
You need to maintain the upper and lower control arms, otherwise cut out and trim as much as you need for clearance. However you will need to add reinforcement, as a tube/plate under the oil pan.
