Old 06-17-2010, 05:47 PM   #41
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: Drooze & Teuton
Yep....whooped....and you are spot on.....
Derher.....
And I do know better......
But yer 100%.....
I like the Poly 318's always have.....
Originally Posted by Myron Piatek View Post
Don't mean to be nit-picky, but to avoid confusion, the Challenger DP 360's are actually considered to be the "Magnum" version. I believe someone said the aluminum heads are re-cast Edelbrock Magnum heads with the Mopar logo. There should be at least a small variety of rockers for them.
A "LA" 360 typically refers to the original style which came with rocker shafts.The family includes 273, 318, 340 and 360. Excluded are what they call the "poly" 318 in the early-mid '60's and the later 318 amd 360's in the '90s that became the Magnum family.
.....You did say you were tired!
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 06-18-2010, 06:44 AM   #42
Liked 1,789 Times in 408 Posts
Originally Posted by Alex Denysenko View Post
I have a question?
What if the rockers are under spec?
We all know that there isn't a factory rocker arm that comes close to spec out of the box so what if your 1.6 ratio factory rockers come up 1.54 or 1.5 rockers are 1.46 etc?
Should you be bounced then also?
Alex, if you read the posts by Travis Miller in the thread I linked above, you'll see that the ratio spec given is the maximum ratio allowed, and if you have less than the maximum ratio, you're fine, and you can make it up with lift at the cam lobe. If the spec is 1.6:1, and you have 1.61:1, you're illegal, but if the spec is 1.6:1 and you have 1.52:1, you're fine. You just cannot exceed the maximum allowed ratio.
Old 06-18-2010, 08:29 AM   #43
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Drooze & Teuton
Thats what I said.....lol.
Old 06-18-2010, 08:50 AM   #44
I know Terry, I'm at a loss as to where all of the confusion comes from.
I've yet to approach Dave, Wesley, or Travis with a tech question that they couldn't explain the answer to clearly. At least, when the rule is in the book, and the information is in one of the guides.
That's not to say Glendora can't muddy the waters considerably.
