Old 08-20-2025, 05:19 PM   #1
Fred Elsass
Liked 314 Times in 44 Posts
Default Is Stock and Super Stock Performance Eliminators.?
It would be if you did the following;
Only class winners run eliminations.
Their fastest run would be their handicap. Breakout in force.
Those who did not win class would have a shoe polish eliminator after class eliminations.
Go as fast as you can.
Sarge
Fred Elsass is offline   Reply With Quote
Old 08-20-2025, 06:31 PM   #2
Billy Nees
Liked 7,854 Times in 1,750 Posts
Default Re: Is Stock and Super Stock Performance Eliminators.?
Just go back to the old way with Class Winners in and the rest of the field the fastest qualified non-Class winners.
Billy Nees 1188 STK, SS
Old 08-20-2025, 06:52 PM   #3
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
And you would get 20 racers to show up! Old ideas from old times. Hate to say it.
Old 08-20-2025, 07:17 PM   #4
Liked 10,895 Times in 2,255 Posts
I believe that there would be a better mix of cars and or trucks if it was class winners and then the rest. Is it not the racers fault no one else built a same class car. Comp style racing belongs in comp. If your the only one in class you still have to run on or below the index to get into the eliminator. Talk about folks stepping it up to get in on time after class winners that will make racers pullout the stops. Indy where AHFS does not belong.
Old 08-21-2025, 07:37 AM   #5
Billy Nees
Larry, I agree with all of the above EXCEPT for the last sentence. Just how long should a 2 second under truck with a ridiculously soft HP factor be protected?
Old 08-21-2025, 09:07 AM   #6
I did not have anything to do with the Hp on the truck. For us it was cheep class car for us to build so Chris could race the Cuda and I the truck. Last time I checked the truck is 29 Hp up from stock.
Back to your question I don?t know but, Indy is the place to Show and Tell without any worries.
Old 08-21-2025, 12:59 AM   #7
GarysZ24
GarysZ24's Avatar
Liked 256 Times in 103 Posts
Unhappy Re: Is Stock and Super Stock Performance Eliminators.?
I sincerely doubt that, given the numbers of racers going to Indy, was significantly large even in the years prior to high dollar race car campaigners influencing NHRA to change who'd make the qualified field!
I don't hate to say this, because I'm certain that many years ago when this change happened, there were posts about racers who lost their class elims, but felt robbed because their .7-.8sec under high dollar cars were left out of the 128 car field, by low buck car's that only ran .5 under their indexes and/or won their classes as single car entries!
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 08-21-2025, 07:28 AM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
Not really a viable idea any more. There is not many national events that contest class anymore. If something like this were to be done then make it the same .50 under to set records be the same trigger for class win and automatic entry to the eliminator
Mike Pearson 2485 SS
