Old 12-27-2007, 02:02 PM   #1
TonyNewberry7274
TonyNewberry7274's Avatar
Default Pro Vs Full Trans Brake?
I am looking to do some .400 tree racing (ss/sg) with a 3600 lb, big block, p/g, chevlle. BTE 1.80 straight cut 5500 stall 5:29 gear, 15/33.5 tire. I need to pick the cars reaction time up. Was wondering if anyone has some info on what I might pick up by going to a pro brake.
TonyNewberry7274 is offline   Reply With Quote
Old 12-27-2007, 02:04 PM   #2
Dave Steltz
Dave Steltz's Avatar
Default Re: Pro Vs Full Trans Brake?
In my supergas car, I went from an ATI bracket brake to a Hipster and picked up about .030...you can also shim out the solenoid and get a little....
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 12-27-2007, 02:13 PM   #3
TonyNewberry7274
With the hipster do you have to hold down the button to back up. And does anyone make one that you don't have to.
Old 12-27-2007, 02:22 PM   #4
Dave Goob Cook
Dave Goob Cook's Avatar
The difference for me between a Coan Standard and Pro brake was about .020.
Dave Goob Cook is offline   Reply With Quote
Old 12-27-2007, 03:41 PM   #5
Rich Biebel
Rich Biebel's Avatar
Liked 555 Times in 216 Posts
Most pro treeT-brakes require the solinoid to be activated to backup and that includes the Hipster. ATI had an internal solinoid style valve body as well as an external solinoid style valve body and both were faster than the average bracket style brake and neither of those two needed the solinoid activated for reverse.
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 12-27-2007, 09:02 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
If the brake change doesn't work put a deeper low gear in it. Make sure you have all the Rev passage dump holes sized right (large) & you have better (stiffer) rev piston springs.
Do you do your own transmisssion work?
Adger Smith (Former SS)
