Liked 105 Times in 26 Posts
Are there any photos available of the damage to Jimmy’s GTO?
Liked 501 Times in 245 Posts
Curious of the actual cause of the mayhem...
Sounded like a flywheel issue. Haven't seen anything like that since the Porter days, and that was a balancer that came apart pre SFI. |
Liked 81 Times in 23 Posts
Here are some photos. This could have been REALLY bad. I have an unconfirmed rumor that the back of the crankshaft broke off. I'm not sure if this is true or not.
Liked 2 Times in 1 Post
I was in the barn when they pulled the trans.
Crankshaft was not broken. What remained of the flexplate was still bolted with all bolts to the crank. Approximately 2/3 of the flexplate was still there. Parts of flexplate and ring gear were gone. The Trans case bell and ears were broken off. |
What happened?
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
Liked 335 Times in 182 Posts
OUCH!!!!!! has he got all his toes??? FED 387
#8 | |
If bolts were loose, and transmission/converter were slightly cocked, the flexplate would be the first thing to go as it continuously bent back and forth with each rotation. If so, the broken surface of the flexplate would leave clues if the failure was a cyclical bending failure. |
#9 | |
James Williamson W200 J/SA. SS/JA Last edited by HR9121; 05-26-2023 at 06:26 AM. |
Oh my God bad is not the word!! Thank God he didn’t stop a few inches sooner. Thanks for the photos and I’m glad both drivers are good. Thank You Lord.
