Old 08-05-2021, 08:34 AM   #1
6130
Liked 117 Times in 50 Posts
Default '94-'96 GM B-body 260/299 LT1 350 sedan or wagon stocker?
Anybody here race one?
Are they a viable combo without having to mortgage my home?
The sedans appear to be natural K cars, and the wagons appear to be natural N cars.
The best off the shelf headers I can find so far, is Hooker's funky #2063 ceramic-coated Super Comp 1-3/4"x3" headers, which appear to sweep up and over.
Is there any advantage to keeping the 4L60E, for it's 3.06 first gear? I don't think a metric 200 would be in the budget for me. It looks like there are proper 8" converters available for them.
Does Global West make Del-Alum front control arm bushings for them?
Who makes lightweight front brake kits for them?
I found single and double adjustable front shocks from Strange, but nothing for the rear.
I'd sure be interested in hearing from anyone that has raced one.
Old 08-05-2021, 08:39 AM   #2
Billy Nees
Default Re: '94-'96 GM B-body 260/299 LT1 350 sedan or wagon stocker
A VERY good combo but IMHO not cheap.
Billy Nees 1188 STK, SS
Old 08-05-2021, 09:06 AM   #3
6130
Thank you, Billy.
Please elaborate. What makes it good?
What would be involved in getting one to comfortably run under, without breaking the bank?
Old 08-05-2021, 10:04 AM   #4
Billy Nees
The biggest thing that "makes it good" is the HP factor. Compare it to an LT-1 Camaro, there's almost 60 HP difference for a slightly different intake and an arguable better iron head.
I don't know what you would consider "breaking the bank". You SHOULD get an aftermarket ECU, a GOOD 3-speed trans and you're going to have to fill up the 8.5 rear with GOOD parts or get a 12 bolt. The only place where I could see you "cheaping out" would be with the motor. I don't see the need for a bunch of trick parts to "comfortably run under" the index but you are going to need a competent shop that understands LT-1s.
Old 08-05-2021, 10:26 AM   #5
6130
Thank you. I noticed the 59 horsepower while going through the classification guides.
Old 08-05-2021, 01:10 PM   #6
joe huestis
Liked 411 Times in 114 Posts
PM Corbitt Marshburn on this site . He has built the LT-1 powered wagon and could guide you down the right path.
Joe Huestis
Youngsville, NC
Old 08-05-2021, 03:25 PM   #7
GUMP
Thank you, Billy.
This is a great combination. Years ago, I worked with GM to get the wagon added. I ended up building another Firebird after Veronica turned her nose up at the idea of me racing a wagon. I still point out every one we pass to her!!
It shouldn't be crazy expensive to build a competitive car. It all depends on what your budget is and how much you can do yourself.
GUMP is online now   Reply With Quote
Old 08-05-2021, 03:43 PM   #8
Lee Valentine
Liked 319 Times in 68 Posts
Billy is right,the engine is where you can save. I've built combos I just wanted to see if they were viable using cast pistons,home brewed low drag ring package etc. that weren't much slower than first class stuff. Good basics and preparation does a lot,might not want to run it forever but good maintenance and common sense driving go a long way. Sorry for the long winded response. Good Luck.
Lee Valentine 1661 STK
Old 08-05-2021, 03:57 PM   #9
6130
Thanks, guys.
I do like wagons...
Old 08-05-2021, 04:25 PM   #10
Jerry Terry
Jerry Terry's Avatar
Liked 451 Times in 134 Posts
Thumbs up Re: '94-'96 GM B-body 260/299 LT1 350 sedan or wagon stocker
I haven't seen a LT1 wagon racing for a while but that is what I would want to build I think that would be a reasonable build and fun to race. I raced 3 wagons through the 70"s and early 80"s loved them.
Jerry
Retired 3490 3492 STK SS SST
