Im looking to buying a new Trans for the up coming season, but i cant decide which way i should go, and on top of that im having a hard time figuring out which ratio would be best for a BBC. im looking at going either with a pro-trans or a metric. what are your thoughts on either of these transmissions, and what would be the ratio suited for a BBC.
We run Pro Trans in ALL our race cars.....It made a dramatic difference
in our performance! Dave is happy to help figure out the optimum ratios for our varied combos. Only a segment of potential possibilities he can build are optimal........Too complicated for my elderly mind. Pro Trans made a significant difference..... Now qualify top 16 rather than towards the middle of the pack with our old junk. I do not know what brand or which eliminator you are running......But if the Smiths build it: It will work RIGHT.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 03-10-2018 at 12:34 AM. |
#3 | |
Liked 976 Times in 311 Posts
I do not want to name names......It was a major trans builder and we utilized the Alum Drums and Straight cut gears from Protrans in our transmissions ...........trying to save a couple bucks.
I will not poor mouth anyone.........They held up well and the transmissions worked great just not the same performance as Dave Smith builds by a Tenth! Dave has been doing this for 40 plus years that I remember. You buy the BEST........You only cry ONCE!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 03-11-2018 at 04:39 AM. |
#5 | |
Liked 319 Times in 68 Posts
Call Sepanek you won't be disappointed.
Lee Valentine 1661 STK |
We run 727 and 904 in our stock or SS stuff/ Glide in No Prep.
I'm running a 70 nova in B/SA. I have been running TH400 for the last 9 years and it works great, I have never had any issues with it, at this point i would like to try my luck with something a little more light weight and trick. I would also like to play with ratios, but I'm unsure witch way to go with that. Pro trans is on my radar for sure! If you don't mind me asking how many runs are you getting out of your pro trans?
Liked 77 Times in 15 Posts
You are in Div. 1, simply call Jack Sepanek. He works with Pro Trans, and is much closer for rebuilds. You won't be dissapointed.
Liked 37 Times in 11 Posts
I second Matt’s post!!! Call Jackie!!!!
Bill Kennedy 1671 SS |
