Old 01-13-2015, 03:14 PM   #1
J.R. Haddad
Liked 1,471 Times in 308 Posts
Question Hydraulic Rollers
Who makes the lowest "plunge" hydraulic roller, or is that the result area
to be looking at? J.R.
J.R. Haddad is offline   Reply With Quote
Old 01-14-2015, 10:22 AM   #2
Lou Jeffery
Default Re: Hydraulic Rollers
We have run several Hydraulic roller cam engines, Ford and Chevrolet using production lifters with no issues. Keep in mind they are relatively low lift Crate motor stock cams. Maybe WE are missing out on some performance but never any problems. Louis Jeffery
Lou Jeffery is offline   Reply With Quote
Old 01-14-2015, 07:08 PM   #3
J.R. Haddad
Hi Lou, thanks for the reply. I'm not having any problem with mine, it is that when I checked them, they drop 145 thousands, and to be legal
I can run one's that only drop 30 thou. Sounds like leaving a lot on the table to me. J.R.
Old 01-14-2015, 09:35 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
When they are running, they wont drop any. You are just measuring the total range that is built into the lifter plunger.
Old 01-14-2015, 11:52 PM   #5
J.R. Haddad
SS3011, interesting. I am trying to learn about hydraulic rollers as I have never run them before. It's interesting the different opinions you can get.
I have had 2 people(1 Racer, 1 Manufacturer) tell me they have back to backed cars at the track, changing oil from 5/20 to 20/50 to keep the lifters "up", and both picked up .03-.04. Keep in mind they also had to overcome the difference in the oil. True story? Who the hell knows.
I'm just trying to buy the right stuff once, instead of twice. J.R.
Old 01-15-2015, 12:16 AM   #6
JR, It isn't very hard to restrict the travel in a hyd. lifter, once you get one apart.
Just have to use good grade, consistent thickness washers. (aviation grade or similar), once you figure out what you need.
Then you won't have to worry about it.
