Hi Everybody,
Just seen NHRA has posted Stock and Superstock Classification and blueprint specs for the 2011-2014 V6 Mustangs, This is a great thing at lest I think so. Just wanted to let everybody know ! Happy Holidays to all ! Tony K. |
Liked 372 Times in 130 Posts
Glad to see it in the classification guide.
Too bad it was rated at 260 hp. Should have been 230 hp, IMO. That combo needs at least 350 flywheel hp to barely run the K/SA index. Looks do-able, but won't be easy because there is almost zero aftermarket support. Long tube headers are available, but that's about it. Not sure if any aftermarket EFI systems will work on that engine. For now it would have to be the factory ecu. That bellhousing bolt pattern might be a challenge for PA transmissions or some other bellhousing maker to mate the C-4 up to it. I believe the 3.5 Ecoboost V-6 has the same bolt pattern., so the investment from them might be worth it. That engine looks like an 8,000 rpm screamer with the right valve springs. Deep rear gears and a deep 1st gear might be the ticket. Lightweight 4500 plus stall convertor ? Or.... a Jerico trans with a custom bellhousing ? I have been researching the 3.7 and cannot find much info on it. Looks like a fun combo once you get past the EFI system and C-4 bellhousing issues.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 12-23-2013 at 09:36 PM. |
#3 | |
Liked 174 Times in 39 Posts
3207 D/SA, C/ED |
Waiting for boosted
Craig Sullivan |
Liked 136 Times in 49 Posts
#6 | |
Liked 275 Times in 76 Posts
Sean
Just more of the same. Ford sponsoring a race next year?
Ed Wright 4156 SS/JA |
There are a lot of cars that are under rated at first ! but it does not matter for as the first guy that goes a second or more under things will start to change adjustments in HP rating, lower index etc. so with that said you have to be a fool to blast the index ! Me personally am happy with 4 to 8 tenths under. just my opinion and you know what they say about opinions !
Tony K. |
#9 | |
Liked 184 Times in 113 Posts
Helped them get Classified through Mike Baker !! AL.. You are gonna have COMPETITION !!! ![]() D |
Dan,
Just E-Mailed Mike Baker on Monday about Classification in Pure Stock for the 2014 Mustang V6 ! did not hear anything yet probably after the Holidays I was down south a couple weeks ago with the Mustang and I got to say this should be a good combo in G/PS trim or close to 3680 lbs with a Tune ,Cold air kit and rear lower control arms and cat delete pipes the best run was a 13.27 @ 105.60 not to bad still have work to do ! Merry Christmas and Happy New Year to all Tony K. |
