Old 01-14-2013, 08:26 PM   #1
Kevin Love
Liked 19 Times in 10 Posts
Default Generator Gas Tank
I am putting an Onan generator in my trailer and was wondering
what size auxilary gas tank everyone has? Also any recommendations
for gas tank suppliers would be appreciated.
Kevin Love 5666 STK/SS
Kevin Love is offline   Reply With Quote
Old 01-14-2013, 09:59 PM   #2
CJ McDonald 9564
Liked 11 Times in 6 Posts
Default Re: Generator Gas Tank
I have a onan in my 48' LQ. I use a couple of 6 gallon plastic boat tanks with a quick connect hose. I like this better than a mounted tank because I can take the tanks in my other pick-up to fill them up. Then when I am at the diesel pump I don't have to move to the gas pump to fill gas tank. For weekend races I carry a few 5 gal cans to refill tanks. I also have a small 2000w gen to save fuel and hours on my onan whenever possible.
C J
CJ McDonald 9564 is offline   Reply With Quote
Old 01-14-2013, 10:33 PM   #3
Matt Schurman
Sponsor
Here is a link to pretty good company that makes tanks in all sorts of configurations. You can get them with sending units installed and utilize a remote fuel gauge.
http://www.moellermarine.com/oem/fuel_tanks/
Matt Schurman
Matt Schurman is offline   Reply With Quote
Old 01-14-2013, 11:08 PM   #4
FED 387
Liked 334 Times in 181 Posts
we use your basic 5 Gal race fuel jugs with a stainless steel pickup pipe/tube tapped into the screw off top with a quick disconnect hose & fitting--easy, cheap and can change jugs quickly for continous operation or for when you need to refill --I have also seen some racers using outboard motor gas tanks they are readily available and easy to move around if you need too
Old 01-15-2013, 04:24 PM   #5
Matt Schurman
Sponsor
In case any of you reading this can't sleep and need alittle help getting drowsy, here is link to the 1/2011 dated EPA emissions required for mobile generators. The fuel system will vent back to the tank from the generator. This is now the required installation method for motorhome/trailer builders.
http://www.cumminsonan.com/emissions/
Matt Schurman
