Old 11-05-2012, 09:38 PM   #1
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
Default Which S/S class can I run in?
I was thinking about going to one of those Stock/Super Stock races this weekend. I've never ran in a class race before. My car is supposed to be legal, I've got my license, the only thing I don't have is a legal weight box. I think my car is supposed to be in SS/DA. Can I run in SS/CA instead? My car weighs 3450 lbs. It is a 2011 V-10 Drag Pak Challenger. Thanks for your help.
rickseeman is offline   Reply With Quote
Old 11-06-2012, 01:39 AM   #2
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Default Re: Which S/S class can I run in?
you will weigh 3545 in SS/DA and 3320 in CA.
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 11-06-2012, 10:05 AM   #3
rickseeman
rickseeman's Avatar
Thank you. I just thought it would be easier to run SS/CA than to install a weight box etc.
Old 11-06-2012, 10:33 AM   #4
Liked 10,756 Times in 2,236 Posts
How much do you and the car weigh ready to go down the track? To run "C" the car needs to weigh with driver 3320 lbs. min to 3544 lbs. max.
Old 11-06-2012, 10:53 AM   #5
jmcarter
jmcarter's Avatar
Liked 3,193 Times in 975 Posts
Since this looks like your first class rodeo I'd thought I'd show you where Larry and Stephen got the numbers...the weight breaks link is right here on ClassRacer..then in the classification guide you get your HP rating which is currently 450 for SS to which you add the nominal driver weight used by NHRA (170lbs). Stick and Auto classes share weight breaks unless noted otherwise. Sometimes people just starting in class forget they need to add the 170.
SS/C 7.00-7.49
SS/D 7.50-7.99
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-06-2012, 12:00 PM   #6
rickseeman
rickseeman's Avatar
Thanks for the info. I didn't want to get over there and be set up wrong.
