Liked 140 Times in 51 Posts
2010 COBRA JET 352
Win class or any heads-up race! Qualify #1! This car will run 1.50 under in E/SA at over 100lbs. heavy, with 6 quarts of XP3, timing backed down, and shifting 500 rpm early! No Ice or chiller needed. If you let it run at its peak, it can go more than 1.70 under. You can also set this car up to run at 1.00 under, 1.10 under, 1.15 under or whatever you like in minutes! #1 qualifier at the Infineon NHRA Divisional and National events. Qualified #6 at Vegas to avoid the AHFS trigger. Only 17 passes made since new. This car was built from a brand new 2010 Mustang and 100% legal for NHRA Stock or Super Stock. Completed in May 2011. Only the right parts and the best parts from the best manufacturers, chassis, engine and transmission builders were used. This car will stay at the top of its class longer than the LT1’s and LS1’s! Complete build sheet available to qualified buyers wow Kevin |
What a perfect combo, sounds like you can't lose! Why would anyone want to mess with an old carbed car with leaf springs and a flat tappet cam??
Kevin, Does this car have a blower on it ? Just asking. Really.
Liked 13 Times in 3 Posts
That combo would not have one.
Chuck |
Found this on another board,I don't think it is a blower motor
Kevin |
Liked 369 Times in 127 Posts
CJ 352's and 428's don't have blowers. They are Fuel Injection-pushrod 351W based.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#7 | |
