Old 11-21-2009, 01:53 PM   #1
BobUnkefer
BobUnkefer's Avatar
Default Stocker engine Input please
68 Camaro that is currently a crate motor car, engine needs freshened, rest of the car works good, is fresh and race ready, .
Question is,,,,, for NHRA Stock eliminator which way would you go power wise?
396/375
396/325
350
327
and WHY? I have my thoughts, but curious as to the more experienced that inhabit this forum as to which way you would go.
It is also my understanding that in a 1968 Camaro, it's a 'Glide only behind a small block, but a 3 speed auto is ok with either big block, Correct?
Thanks for your thoughts,
Unk
BobUnkefer is offline   Reply With Quote
Old 11-21-2009, 02:05 PM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: Stocker engine Input please
396-375 says Stick only for 68
Bob Pagano A/SA
Old 11-21-2009, 02:16 PM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
I would go either 327 or 350. This way you can run in both IHRA and NHRA. A PG is the only automatic behind these combinations. The 327 is a great stick combination!!!!!!!!!!!
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 11-21-2009, 02:38 PM   #4
BobUnkefer
BobUnkefer's Avatar
Bob,
IHRA has 396/325 in their book I'm sure. We're looking to make car a legal NHRA stocker and get away from the crate motor aspect.
Looking @ Nitro Joe's stats, It doesn't appear that a '68 Camro/350 is a combination found very often, yet there are numerous 327's. Looks like they've defactored thr 350 combo as well. Is the 350 just not a workable combo, or is the 327 that much BETTER?
BP, missed the stick only on the 375hp
so that leaves a 396/325 for D/SA, or the 350 or 327 for G/SA if I'm reading correctly,,,,,, and please correct me if I'm wrong.
Old 11-21-2009, 04:31 PM   #5
Jeff Lee
Jeff Lee's Avatar
Old rule was "PG Only", now you can run a 3-speed auto in lieu of 2-speed auto. They seem to go quite a bit faster with this change...
Jeff Lee 7494 D/S '70 AMX
Old 11-21-2009, 04:53 PM   #6
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: Stocker engine Input please
Not in stock.....Super Stock only.
Old 11-21-2009, 06:09 PM   #7
Michael Kilduff
Originally Posted by BobUnkefer View Post
Bob,
Bob,
This summer I spoke to a noted and well respected stock/superstock engine builder about this very subject as I have a '68 camaro that I sometimes think about running as a stocker (it is a street/strip car now). He told me that in the heat the 350 seems to run better and is more consistent than the 327. Other than that it is pretty much a toss up.
As a note the 350 camaros in 67/8 were Super Sports which probably means you have to use the correct SS hood and louvers which I think weighs about 30 pounds or so more than a flat hood.
I'm not aware of any other significant differences for class racing between the 350 SS and the 327 base/RS 67/8 camaros.
Michael Kilduff is offline   Reply With Quote
Old 11-21-2009, 06:19 PM   #8
Jeff Teuton
Liked 325 Times in 50 Posts
It's being done @ B & B. Hope to be out in Feb. I will start with the 360 in H/SA. Need a Mopar? I got plenty.
Jeff Teuton 4022 STK
Old 11-21-2009, 07:59 PM   #9
Bob Gullett
Talking Re: Stocker engine Input please
Bob,
I guess I should have said that a traditional combination and not a crate motor is the way to go. I'm just biased to the 327!!!!!!!!
68 Chevy11 327 F/S
Old 11-21-2009, 09:37 PM   #10
Doug Domm
Liked 84 Times in 21 Posts
I have both a flat hood and an SS hood and weighed both of them and found barely 5 lbs. differance using a very accurate digital scale. Now having said that neither hood have any bondo but both have a significant amount of paint on them.
Doug Domm is offline   Reply With Quote
