Old 06-22-2009, 08:43 AM   #1
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Default No Records At Denver??
Raced this past weekend at the Div. 5 points race at Denver, and had the "R" on the window for the first 4 runs. Never did any tech offical stop to seal the engine or even acknowledge the attemted runs. Dad raced with his sea-level combination, because he didn't want to put the record out of reach for future races, and didn't run far enough under to really worry about it, but tech completely ignored the runs (which were all under his current record). Plus, the record expires later this year. How can this occur, and has anyone ever experienced this before? Seems to me, since you can't set records on the National level, that NHRA would be prepared for this at all Divisional events.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 06-22-2009, 03:31 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: No Records At Denver??
I've been down the path of "we never saw the "R" in your window so none of the runs count"
It wasn't a bad thing as I came back at the next event and went even deeper against the old record
You need to make sure your R is seen by officials.
Jeff Lee 7494 D/S '70 AMX
Old 06-22-2009, 04:09 PM   #3
james schaechter
Liked 1,450 Times in 303 Posts
Exclamation Re: No Records At Denver??
Sometimes the crew at the scales relies on the tower to call out record breakers on record attempts since the crew at the scales would not have that info. I was entered in O stick once in a friend's car and went under the record. They had me in the computer still as M stick so they didn't realize I was under the record. If I had not stopped at the scales and asked, I would not have been fuel checked or sealed. If they don't do that, no valid attempt. Bottom line, if you are on a record run, don't leave the scales until you are sealed and checked.
Didn't Tony Hernandez drop a bomb on F stick? I thought he was going for the record.
James Schaechter 3163 STK
Old 06-23-2009, 02:52 PM   #4
Jack McCarthy
Liked 511 Times in 122 Posts
Talking Re: No Records At Denver??
hell you were just in the wrong division...
TRY to get past travis, you get sealed on the scales.
and in division 2 SEVERAL years ago i tried to set at orlando, was .01 short... later was racing brackets and still had R on window and was invited to tear down !!
captain
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 06-23-2009, 02:55 PM   #5
Jack McCarthy
p.s. i've notice a lot less R's on those window since we started pouring heads ... hehehe
jack
"the Captain"
Old 06-23-2009, 03:13 PM   #6
hadtobethere
jack
....Now that is funny and it is true....I wonder why?
hadtobethere is offline   Reply With Quote
