Old 08-15-2008, 04:11 PM   #1
K Stubbs
Liked 20 Times in 3 Posts
Default Who does the best LS1 stock eleminator cylinder heads?
I am building an LS1 stock eliminator car and want your (racers, engine builders, whoever) opinion on the best head person for this combination (241, 806, etc). I have spoken to a few of the head builders already, just looking for more input. First and foremost they MUST pass tech. Thanks for any info.
Kevin Stubbs
K Stubbs is offline   Reply With Quote
Old 08-15-2008, 07:58 PM   #2
Liked 11,010 Times in 2,263 Posts
Default Re: Who does the best LS1 stock eleminator cylinder heads?
Gm
Old 08-15-2008, 08:00 PM   #3
Liked 1,927 Times in 433 Posts
Talking Re: Who does the best LS1 stock eleminator cylinder heads?
Originally Posted by larry hill View Post
gm
Now THAT is funny.
Old 08-15-2008, 08:46 PM   #4
Smile Re: Who does the best LS1 stock eleminator cylinder heads?
Larry -- That would be with a capital M please as in "GM"................
Old 08-16-2008, 11:18 AM   #5
Torque addict
Everone know that GM stands for = GENEROUS MOTORS!!
LOL
BTW don't you folks know that as per the rule book HEADS and INTAKE MANIFOLDS are to be STOCK ELIMINATOR and UNMODIFIED with only valave jobs allowed? "AS IF"!!
... and in SS well that is the whole other world of "Limited Modifications"
(said with tongue firmly planted in cheek)
Cheers;
Derek
Torque addict is offline   Reply With Quote
Old 08-16-2008, 01:05 PM   #6
Torque addict
Originally Posted by 1664SSJA View Post
You must be reading and OLD rulebook if you read "limited modifications"............. acid porting, epoxying, and welding gets a LITTLE involved!
LOL...while the phrase"Tongue in Cheek" is NOT listed in the NHRA rule book, I think you know what I mean.
Even STOCK heads are no longer stock if you want to be competitive! Modified heards and intakes should be boundes in Stock.
They used to bounce guys for the wrong supersceeded part number on a carb float when things were "stock" now $20K + stock motors bulit by pros on order for an amateur "grassroots/littleguy" class are permitted.
What BS.
Old 08-16-2008, 04:52 AM   #7
FlyingW
FlyingW's Avatar
If I was having as set of competition LS1 set of heads built I would say Little W.J. as in Mr. Woodro Josey .
Jeremy Waibel
Driver of the K&N 69 Camaro
NHRA B/SA 2231 stk
FlyingW is offline   Reply With Quote
Old 08-16-2008, 10:22 AM   #8
Jack, Just got back from the "Dyno" and was feeling a little down and hit send before I looked at my post, It is GM.
Old 08-16-2008, 10:55 AM   #9
K Stubbs
Thanks Larry, I will keep that in mind knowing that you run "chrysler" heads on your combo.
