Old 04-19-2024, 10:30 AM   #1
Liked 11,032 Times in 2,267 Posts
Default Engine assembly bench or engine stand
What does best as far as making power or is there any difference?
Old 04-19-2024, 10:55 AM   #2
Frank Castros
Liked 2,798 Times in 983 Posts
Default Re: Engine assembly bench or engine stand
Bob Glidden never use an engine stand.
Old 04-19-2024, 11:45 AM   #3
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Engine assembly bench or engine stand
Good morning to all,
I also understand that Jack Roush didn't use an engine stand either!
Funny, both Ford guys, both very powerful................
Might be something to it.
Have a Good Day.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 04-19-2024, 12:38 PM   #4
Dirk Olson
Liked 172 Times in 46 Posts
Not sure what is being asked here?????
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 04-19-2024, 01:08 PM   #5
Eman
Liked 133 Times in 76 Posts
I'll take a guess. Some use the theory that engine stands letting the engine hang puts abnormal stress on the block. I'm sure it can make a difference and if you want to you can assemble on a bench.
Old 04-19-2024, 06:57 PM   #6
SSDiv6
Here you go Larry:
https://www.rcrmetalfab.com/engine-assembly-stand.html
https://www.redlinestands.com/catalo...e-stand-p-2638
http://www.axeequipment.com/engine-stands.html
Old 04-19-2024, 07:32 PM   #7
Mark Ugrich
Liked 71 Times in 38 Posts
The story I remember about Glidden not using an engine stand was that it pulled the two rear cylinders out of round.There may be some merit to it. That said, I’ve always used an engine stand.
Old 04-19-2024, 08:09 PM   #8
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
If it pulled them out of shape which is very possible with a stock Ford block, it should still go back to where it was when taken off the stand. A cylinder will go out of shapre with the plate or head off but go back in shape when they are put back on.
Old 04-19-2024, 08:56 PM   #9
Mark Ugrich
“ should go back” might be the key phrase there.I’d think they would have some resiliency but how much? I don’t know if Glidden sleeved any of his blocks,but if he did that would change things also.
Old 04-19-2024, 09:23 PM   #10
I've always used a stand. At least to finish. I have put the cam and crank in on a table, some times. But always finished on a stand.
