Liked 242 Times in 81 Posts
What kind of setup are you stick guys using for a clutch switch to control 2 step? I never had a switch on the clutch just button on shifter. Pics would be nice.
Thanks, Rod
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
I use a Biondo switch working off the Z bar. It allows you to dial it in so it releases just where you want it to!
Don Fardie 1582 F/S B/G |
Liked 885 Times in 238 Posts
Don's setup looks pretty nice.
I may have to try that on my next clutch job ! I've used the Jerry Bickel switch in the past which is a very heavy duty switch with molded in leads and an adjustable arm . they also have a universal mounting bracket for it.
Liked 24 Times in 13 Posts
What is the issue with a switch on the shifter in Stock.
I believe the SS people are allowed one on their shifter. Terry K |
#5 | |
Thanks for the replies guys. I am exploring options on the set up. I assume that both those switches have to be adjusted every time the clutch is adjusted correct? Is one more user friendly than the other? I have figured out how to use 2 relays to lock the line lock and 2 step together just working on clutch switch configuration and location for ease of use.
#6 | |
Liked 920 Times in 259 Posts
I've put these on a number of stick cars for guys. Fab a mounting bracket and a tab on the pedal to actuate it. Infinitely adjustable. Guys like them fine. |
#7 | |
Thanks, Rod
#8 | |
http://www.jegs.com/i/JEGS-Performan...10353/10002/-1
Liked 39 Times in 13 Posts
Rod, I use the Biondo switch. I drilled a hole in my clutch pedal and the switch comes through the hole! When my foot is on the clutch it is activated! Works fine!
J. Wayne Totaro 1117 STK |
Liked 125 Times in 33 Posts
Rod,
I use an OMRON switch P/N D4C-1620 (actuated by the clutch fork). It looks very similar to the Jerry Bickel switch, but it can be found on ebay for ~$15 new. Tim |
