Old 04-18-2007, 06:52 PM   #1
Sean Ward
Sean Ward's Avatar
Send a message via AIM to Sean Ward
Default whats the most you picked up changing fuel brands
just wondering because i have never used vp until this weekend and picked up a ton i say a ton because it was a half sec is this even possable ijust dont see it but that is all we did to the car was fuel
any input wanted
sean ward
stk# 2882
Sean Ward NHRA s/ss/comp#2882
SW4 MOTORSPORTS
Sean Ward is offline   Reply With Quote
Old 04-18-2007, 07:22 PM   #2
Sean Ward
Sean Ward's Avatar
Default
seen couple hun picked up by changing fuel anyone got an answer
sean ward
stk# 2882
SW4 MOTORSPORTS
Old 04-19-2007, 07:41 AM   #3
Mike Galuk
Default
Sean, what fuel were you using, and which VP did you put in the car? Mike
Mike Galuk
JOE COOL RACING
M/SA-2080
Mike Galuk is offline   Reply With Quote
Old 04-19-2007, 12:01 PM   #4
junior barns
Liked 20 Times in 14 Posts
Default
is it possible that the gas in your car was last years and it was very stale and or the tank was low. made a pass on stale gas along with low level in tank, then added new fresh gas and plenty of it so pick up in tank never got any air and now alot of e.t. shows up. not really just fuel change that made .50 pick up in e.t.
junior barns is offline   Reply With Quote
Old 04-19-2007, 01:55 PM   #5
Bryan Worner
Liked 535 Times in 86 Posts
Default
I don't see much gain or loss in any legal fuels! I used C12 and C11 a few years ago. Switched to Sunoco Blue (Supreme) and now use Sunoco Purple. I've run just as fast, if not faster with the Purple than I ever did with either VP!
The only gains of any significance were a few years back with the ERC, which is now illegal, although you still get a whif of it every now and then at the track!!
Bryan Worner is offline   Reply With Quote
Old 04-19-2007, 02:59 PM   #6
Sean Ward
Sean Ward's Avatar
Default
i have always used sounco purple 110 the gas was not old i just did not have enough to get through the weekend so i drained it and had to puschase vp c12 and thats what i put in the car and it just flat ran also my dad runs vp in his car but it doesnot make a differance we have play with fuel on his car before but no diff so we never tried it on mine
sean ward
stk# 2882
SW4 MOTORSPORTS
Old 04-19-2007, 06:58 PM   #7
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default
Picked up .03-.05 in the 1/8th going from Sunoco Purple to Torco Blue.
All depends on your jetting, though. Different fuels may need different setups.
Michael Beard
Staging Light Graphic Design & Printing
Duck Tape/Loctite Racing
J/CM '80 Volare 360 Magnum - World Record Holder
Old 04-19-2007, 07:10 PM   #8
Sean Ward
Sean Ward's Avatar
Default
it really should run on pump gas its only a 318 mopar Q/SA 8.5.1 motor not big at all
sean ward
stk# 2882
SW4 MOTORSPORTS
Old 04-20-2007, 12:36 AM   #9
Chris 2421
Default
Shell has a line up of racing fuels suppose to be real stable.100unleaded 105unleaded - 110 leaded -114 leaded-118 leaded
Where did you find the info??
Nautilus Racing
Nautilus Racing
Chris 2421 is offline   Reply With Quote
Old 04-20-2007, 10:59 AM   #10
Bryan Worner
Default
Beard.....03- .05 in the 1/8, just swithing fuels? That would be about .10 in the quarter!!! What else did you do? Change tires, take weight out and ice the intake??? Or did you spin on the first run and hook on the second??
There are too many variables, I think, to just say a fuel picks you up over another fuel. For example, did you cool all of your fluids down to where they were on the first run? I know my car picks up a little on the second run, just from the oil, trans fluid and rear end being warmed up. Did you run the same lane? Did you leave the line exactly the same? Did you shift at exactly the same rpm?
I was comparing et's from my log books from when I used VP, Sunoco Blue, and now Sunoco Purple........and I've found I'm running faster now then ever. So take it for what it's worth!!
