Old 11-03-2013, 10:02 AM   #1
rob7181
Default SR-20 Headed motor in a Davis C5
Anyone put an SR20 motor in a Davis C5 corvette? Trying to figure out if there will be hood clearance issues, as there is not a lot of room under there.
rob7181 is offline   Reply With Quote
Old 11-03-2013, 08:18 PM   #2
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
Default Re: SR-20 Headed motor in a Davis C5
The head is probably fine....but what deck height...?
Rock Haas
CBS is offline   Reply With Quote
Old 11-04-2013, 09:56 AM   #3
rob7181
Rock,
Will be using a 9.8 deck height block. According to my calculations form crank centerline:
The valve covers are 2" taller on the SR-20's
The Carb flange on the intake is 2 3/4" taller then the edelbrock BBC intake on my current engine.
I dont believe the heads will fit under the hood.
Old 11-08-2013, 11:11 AM   #4
Tom Joseph
You will have no problems
Tom Joseph is offline   Reply With Quote
Old 11-08-2013, 03:55 PM   #5
rob7181
Tom, been doing some measuring and it looks like the body will hit the valve covers when it comes down. Do you know someone that has done it with a Davis C5?
Dont want to spend the money on the heads and associated parts and end up with an engine that I can't shut the proverbial hood on
Old 11-08-2013, 04:12 PM   #6
supergas4
Liked 6 Times in 5 Posts
call kevin at davis.
supergas4 is offline   Reply With Quote
Old 11-12-2013, 09:00 AM   #7
rob7181
Tom,
Could you email me Rob7181@verizon.net
Thanks,
