Old 12-20-2011, 11:05 AM   #1
Glenn Quinn
Glenn Quinn's Avatar
Default Front tire size and RT
I currently run a 24” X 4.5” X 15” front tire @ 33 psi. Since I will be replacing them this off season, I was wandering how a taller or smaller diameter tire will affect RT.
Glenn
Glenn Quinn is offline   Reply With Quote
Old 12-20-2011, 10:34 PM   #2
Bill Baer
Default Re: Front tire size and RT
Taller tires have a little more roll out and will slow your reaction time smaller ones will do the inverse. I run a 5.00-5 on my S/C dragster they are .02-.04 quicker that the regular 17" dragster wheels/tires but you must stage very carefully with them.
Old 01-22-2012, 11:58 AM   #3
Smallbloc
I've had many-.005 red lights with a 26'' tire
Should of had a 28'' tire!
Smallbloc is offline   Reply With Quote
Old 01-26-2012, 07:07 PM   #4
Timetraveler
Liked 12 Times in 6 Posts
It all depends on your car and class. If your getting good RT with what you have been running then I would say stay with it.
I have a 66 Belair with a 383. For a full tree I use 30" but when I run a .500 pro tree I can't go red with them so I run a 26" and they work great.
Timetraveler is offline   Reply With Quote
Old 01-27-2012, 11:31 PM   #5
RULER
Liked 58 Times in 18 Posts
Question Re: Front tire size and RT
What????????
RULER is offline   Reply With Quote
Old 02-01-2012, 04:22 PM   #6
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Unless you are blocking, you can find several hundredths difference in R/T on a Full Tree vs Pro Tree.
2" in tire size will get you roughly .015.
For more information join www.thisisbracketracing.com. There's an extensive 10+ pg editorial on bottom bulb reaction times and how to adjust them.
