Old 12-05-2011, 06:41 PM   #1
Rick Schilling
Liked 14 Times in 10 Posts
Default 462624 Chevy head question
Does anyone have knowledge about the differences in 462624 small block Chevy cylinder heads? I know that for the most part, they are light weight castings (scalloped along the lower edge) and can be somewhat prone to cracking. There seems to be, however, multiple versions of the same head, all with the same casting number. Some are scalloped and some are not. Some have different markings on the ends than others. Some are found on GM crate motors made in Mexico and there is also a marine version. Which ones are preferred and how can they most easily be identified?
Rick Schilling is offline   Reply With Quote
Old 12-05-2011, 06:57 PM   #2
FED 387
Liked 336 Times in 183 Posts
Default Re: 462624 Chevy head question
probably the worst if not one of the worst heads Chevy ever made!!! TOTAL JUNK!!!! Look at a used set of used Vortec or Dart heads---New better to start with right out of the box--- fix em up for hi po if ya want---my opinion---Comp
Old 12-06-2011, 06:19 AM   #3
Bobby Zlatkin
Bobby Zlatkin's Avatar
Rick, you're right, they are light weight castings and prone to cracking.
However, if that is what you are required to run, then you have no other choice. I would look for the heaver, flat accross the bottom 'made in Mexico' heads. I think there is more meat there. They were used on early crate motors (late eighties, early 90's.) back when they were called 'Target Master' motors.
Your best bet on finding a pair would be in a junk yard, out of a truck. I was lucky. I found a virgin pair of Target Master "made in Mexico" heads at a swap meet.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 12-06-2011, 10:18 PM   #4
pmrphil
Liked 398 Times in 153 Posts
I believe that some of the truck applications also had 3/8 exhaust stems
Phil Molski
PMR Performance
S/C 1623
Old 12-08-2011, 02:21 AM   #5
rustbucket79
Truck heads were 1.72/1.5, car heads were 1.94/1.5, and they were offered over the counter with 2.02/1.60 (a la L 82 heads) We've never come across a set of heavy castings with that casting number.
rustbucket79 is offline   Reply With Quote
Old 12-08-2011, 01:52 PM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Rust bucket is correct to add to his info I don't remember a Mexico version.
Mike Taylor 3601
