Old 06-21-2011, 04:12 PM   #1
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Default Can a slick be patched or plugged?
Has anyone had any good or bad luck trying to patch or plug a slick? I have a screw in one of my tires and it only has one pass on it.
Thank you,
Larry
Larry Curtis is offline   Reply With Quote
Old 06-21-2011, 04:36 PM   #2
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Default Re: Can a slick be patched or plugged?
Thank you,
Larry
I did it with one of my hoosiers, but it was a radial and then only as an emergency for my dakota..Never had to use it...But it did hold air for 2 plus years....I didn't bother patching the hole in the dragpak's hoosier after 12 runs.....as it fell into the catagory of do I really want to role the dice on it not working out with that much HP and $....
Yours is a stick car correct?
Eric
Eric Merryfield 1883 STK
Old 06-21-2011, 04:38 PM   #3
Larry Curtis
Yes it is a stick car and has bias plies on it.
Old 06-21-2011, 05:37 PM   #4
Joe DeMarzo
Liked 123 Times in 11 Posts
After the first bun out the plug is melted in, no problem getting 75 runs on a plug.
Joe DeMarzo 1317 STK
Old 06-21-2011, 06:20 PM   #5
Rory McNeil
I have sucsessfully used "patch plugs" on bias ply slicks. These are a combination of a round patch with a plug in the center.
NHRA 6390 STK
M/S 85 Mustang
Old 06-21-2011, 07:21 PM   #6
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: Can a slick be patched or plugged?
Larry, I feel your pain. I have several sets of Hoosier and Mickey Thompson slicks I could send you. My partner wants to keep fresh tires on the car. Imagine that. Do not patch that slick. You have a lot invested in your car to take a chance like that. Think about it?
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 06-24-2011, 11:24 AM   #7
Vic Santos
Vic Santos's Avatar
Liked 14 Times in 2 Posts
Larry, I have plugged many slicks and the only one I had trouble with was a slick someone brought to me with the cords showing. I use only the rubber "umbrella" plugs. They require a special gun and come in two diameters; I use the 3/8" size. The gun is used to extrude the seal into the tire, the umbrella opens inside the tire and is pulled onto the inside suface of the tread when the gun is removed. Works great! I bought it at NAPA and I keep it in my glove box for places like Maple Grove.
Vic
Vic Santos is offline   Reply With Quote
Old 06-21-2011, 04:37 PM   #8
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Both are done all the time and many racers including myself carry and have used a plug kit at the track and in the lanes.
Old 06-21-2011, 09:23 PM   #9
Shawn Blair
Shawn Blair's Avatar
Wink Re: Can a slick be patched or plugged?
Larry, I've always plugged mine and never had a problem!
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 06-21-2011, 09:34 PM   #10
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
I plugged a M/T radial stocker tire and had no probelms with it. Used a std fast plug kit and made the next round after finding a tire going down in the lanes.
Took the tire off and redid the pug with a mushroom type plug and used a red vulcanizing sealer from the inside. Wore those tires down to the cords....never was any problem....
I would not hesitate to just use the gooey std twisted style red plugs....Once they set in there they seem to last fine even in the thin tread....
Rich Biebel
S/C 1479
Stock 147R
