Old 07-13-2010, 03:49 PM   #1
ken robinson
Liked 225 Times in 88 Posts
Default Is my brake porportioning valve bad
Has my 67 camaro brake porportioning valve gone bad ? All of the 4 drum brakes work and hold strong and release fine .The main problem is with line lock it just can't lock down front brakes . Put new hurst line lock in end of last year , just due to the old hurst line loc soleniod started to stick/died . It just seams like it holds at half the pressure , compaired to if you just push on the pedal and try to turn the wheels . The line lock is get full 12vdc . All line connected wright in and out . Its the only thing left . Anybody run in to this ? Ken R.
Old 07-13-2010, 03:59 PM   #2
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Default Re: Is my brake porportioning valve bad
On my 70 challenger its pretty similar if I don't pump the living crap out of the brakes first. Much more than the other cars(dakota and challenger09). I think you may have solved a nagging problem for me!
Eric
Eric Merryfield 1883 STK
Old 07-13-2010, 06:18 PM   #3
ken robinson
Ya thats what I've been doing just to get by . But it can push you wright out of the burn out and miss putting enought heat in the slicks . I dont think my cars got a porportion valve , I think its just a pressure switch that lights the dash light .
Old 07-13-2010, 06:38 PM   #4
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Your last comment is correct- drums on all four won't need a proportioning valve. Try adjusting the shoes to the point they start to drag.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 07-13-2010, 09:17 PM   #5
FED 387
Liked 336 Times in 183 Posts
-try adjusting shoes til they start to drag ---then when you get into the water box pump the brake pedal a few times til it starts to get hard---you'll feel it in your foot--- then with the pedal still on the brake pedal set the line loc ---then start your burn out see if this helps--worked on my 67 camaro with drum brakes--Comp
Old 07-14-2010, 06:09 AM   #6
Billy Nees
Liked 7,925 Times in 1,760 Posts
Ken, have you put new lining on it lately? Did you have the new lining re-arched to the drums?
Billy Nees 1188 STK, SS
