Old 08-11-2023, 01:21 PM   #1
Keith Rittenberry
Liked 4 Times in 2 Posts
Default 1966 Chevelle Malibu SS/NA
283 ci class, Power glide (2.18 low gear), Cheetah shifter, A1 7” converter. Fresh engine with 3884520 Chevy Power Pak heads by Heads Up from many years ago, but freshened in Aug 2023 by Wes King. New Dart SHP bock, Eagle lightweight crank, CP pistons and rods, Bullet custom grind roller cam, Crower Hippo roller lifters, Jesel shaft rockers and belt drive with crank trigger, Victor Jr. intake, Rochester 4GC (four jet) carb, dual Holley electric fuel pumps, MSD 7 ignition, aluminum radiator with dual electric fans, aluminum lightweight water pump, new battery, weight box, etc. Four link rear suspension with a GM 12 bolt and 6.14 gears. Tubbed with new 30X10.5X15 Hoosier drag radials. Room for 32x14 slicks, if wanted. Runs well under the index, even at 4000 ft. Body is laser straight and the interior and underneath are solid and very clean. All steel body, of course. Call Keith at 952-250-3145 or email at krittenberry1953@gmail.com for specific pictures you wish to see. $35,000 OBO.
Keith Rittenberry is offline   Reply With Quote
