Old 11-10-2019, 10:53 PM   #1
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Question Did You Get Screwed?
It has come to my attention that there was at least one, maybe more competitors who ran the 1976 360 (Volare, Aspen) combo at Indy this year who were DQed for having a smaller primary (1 3/8) Thermo Quad than tech said they should have. In previous tech info printed on the NHRA Tech site it stated you could run either the 1 3/8' or the 1.50' primary TQ carbs as both carbs numbers were listed as original equipment. Apparently these tech sheets have been re done and the small primary carb was left off the list but the Carburetor OEM numbers are still there.
I have been building these TQ carbs for Stock and Super Stockers for more than 40 years and Both carbs are and have been listed in several 360 combos and are both listed as OEM for those combos.
If you were one of those who were DQed for this reason please contact me so I can verify this with NHRA Tech. I plan on following up this mistake with NHRA and will keep you informed on how this turns out. If this has happened, I'm not sure what can be done to compensate those affected but either way, this needs to be addressed. Jim
jimwahl@embarqmail.com
Old 11-10-2019, 11:01 PM   #2
Jim Wahl
Jim Wahl's Avatar
Exclamation Re: Did You Get Screwed?
I understand it was Wesley who was DQing racers for this. I was NOT there and this was reported to me by someone who WAS there.
No matter what. This misprint needs to be corrected before others are affected by it! It can be varified by Carter and several places including Chrysler MoPar Parts listings. Jim
Old 11-10-2019, 11:02 PM   #3
MR DERBY CITY
Liked 8,114 Times in 1,531 Posts
Default Re: Did You Get Screwed?
There were 3 DQ s in Stock at INDY, none were dismissed because of a TQ violation....
Old 11-10-2019, 11:23 PM   #4
Jim Wahl
Jim Wahl's Avatar
OK, Were there any DQ's for that reason at any race this past year that anyone knows of? It would be great if that were the case but regardless the tech sheet is wrong and needs to be corrected. Thanks MJ! Jim
Old 11-11-2019, 01:35 AM   #5
Rod Greene
Liked 242 Times in 81 Posts
To my knowledge no 360 ever had the small carb from the factory.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 11-11-2019, 08:39 AM   #6
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: Did You Get Screwed?
The '78 Aspen wagon 360/160hp has had both sizes listed in the tech sheets. One reason I liked it was because it provided more options and bettered the odds of getting a good core. But many of the later 360-4 specs are blanketed with a 289 HP factor anyway, regardless of cam size or carb size!
LOCOMOTION Racing
Old 11-11-2019, 01:30 PM   #7
Jim Wahl
Jim Wahl's Avatar
Actually every 360, 340 and 318 TQ equipped combo was offered with the small (1 3/ 8 ) primary. Very few list the large secondary carb. The large secondary was mainly offered in big block combos although some BBs came with the small primary only. I have the lists of every Carter TQ that was offered by Chrysler and what year, C.I., and it's part number. Be glad to send it to you. Jim
Example: If you look up the 1976 Volare with the 360 engine in the NHRA blueprint guide, it will list 5 TQ numbers accepted by NHRA. The first two of these are small primary carbs and the other three are large primary carbs.
Old 11-12-2019, 01:25 AM   #8
GTX JOHN
Jim is right.....Both small and big carbs have been legal on that combo
for as long as I can remember.
However, I never find ANY Difference in performance on a 360
between the big and small carb.
We have set the National Record a few years back with a 360 combo
and the carbs varied more one to another without consideration of size
of primary.
John Irving
741 Stock
741 Super Stock
Old 11-12-2019, 06:34 AM   #9
devo340
devo340's Avatar
Liked 168 Times in 30 Posts
We run a 1980 Volare 360 combo.
It has a small bore TQ on it, by the carb number, it's for a 1974 360.
Got torn down this year, carb was checked & found legal.
devo340 is offline   Reply With Quote
Old 11-12-2019, 01:37 PM   #10
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Jim I haven't been Screwed in a long time.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
