Old 10-02-2007, 08:03 PM   #1
rgarvey
Question barry grant fuel pump
anybody ever seen a issue with the barry grant pump having inconsistant fuel pressure? the pump im refering to is the 280 bg
rgarvey is offline   Reply With Quote
Old 10-02-2007, 08:41 PM   #2
Caperat
Angry Re: barry grant fuel pump
If you have a BG -2 port regulator, that could be your problem. Myself and a few other racers had new ones that were junk out of the box. Some guys even bought them twice and it only resulted in twice the headache. ---- Kevin ---
Caperat is offline   Reply With Quote
Old 10-02-2007, 09:45 PM   #3
sidney norwood
Question Re: barry grant fuel pump
I had the same problems with the BG 400 pump caused by premature wear of the rotor or vane and housing inside the billet base. The pump lost 25% of the pressure in less than 150 passes. I am sending it back for rebuild the second time in two years. Thinking about going to an Aeromotive pump.
80Corvette
sidney norwood is offline   Reply With Quote
Old 10-02-2007, 10:12 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Thumbs down Re: barry grant fuel pump
A couple of years ago i bought a BG280 pump and 2 port regulator. The fuel pressure was all over the place. One minute it would be a 7 lbs and the next over 10. If i reved up the engine it would drop below 5. When it did creep up above up the carb would flood. Jegs sent me another regulator with the same results. I put back on my old Mallory regulator and the fuel pressure stays at a constant 7 psi. I now have another BG regulator but it can stay in the box as my mallory regulator works fine. The BG pump works great but the regulators are junk.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 10-02-2007, 10:13 PM   #5
Chad Rhodes
Default Re: barry grant fuel pump
Get rid of it and get a MagnaFuel. They are field servicable for $20, balanced stator (no more leaks between the motor and pump), and a much better company to deal with. I would not put a BG pump back in one of my cars if it were free...............(excpet the one I had to borrow from Little Joe at Atlanta Last year)
Chad Rhodes 2113 I/SA
Old 10-03-2007, 08:33 AM   #6
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
I have one, real consistent. Works great- as a wheel chock.
2894 STK
Old 10-03-2007, 09:10 AM   #7
Dave Goob Cook
Dave Goob Cook's Avatar
Never had a bit of trouble with one of these....
Dave Goob Cook is offline   Reply With Quote
Old 10-03-2007, 10:29 AM   #8
Rusty Davenport
Liked 101 Times in 27 Posts
Anybody have anything to say good about Barry Grant stuff ???????
Rusty Davenport is offline   Reply With Quote
Old 10-03-2007, 12:35 PM   #9
Real Racer
Nope!
Real Racer is offline   Reply With Quote
Old 10-03-2007, 05:55 PM   #10
rgarvey
thanks to everybody who responded barry grant out aeromotive on its way
