Old 11-26-2015, 03:20 PM   #1
Randall Klein
Liked 316 Times in 67 Posts
Default Opinions or experience with ISKY E-Z roll lifters
Anybody using the Isky E-Z roll lifters? I see Bullet advertising same idea
Old 11-26-2015, 07:18 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Opinions or experience with ISKY E-Z roll lifters
I use the crower bushed lifters .best thing I ever did. This is in a 10 k rpm eng. No power loss. Went 3 seasons on the lifters. And I am just going to replace them out of guilt. No more fear of broken needles wrecking everything.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 11-26-2015, 07:51 PM   #3
SSGT Mustang
Liked 204 Times in 54 Posts
Mark,
What kind of spring pressure are you running? Also, any brass in the filter from the lifter bushings?
Thanks,
Steve
SSGT Mustang is offline   Reply With Quote
Old 11-26-2015, 08:29 PM   #4
Mark Markow
Originally Posted by SSGT Mustang View Post
Mark,
Thanks,
Steve
345lbs. on the seat new . and change them if they get down to 320 ish. #1356pac. nothing in the filter, and never see any change in the lash either. also running copper inserts in the pushrod cups. they are a radius cup pushrod and ball adjuster
Mark Markow
171 ss/tb
Old 11-26-2015, 09:12 PM   #5
SSGT Mustang
Thanks, Mark.
Old 11-27-2015, 10:59 AM   #6
carl hinkson
Liked 18 Times in 10 Posts
I have seen alot of sizing issues with those lifters I have had to buy 2 if not 3 sets to make up one set because of sizing issues.
So make sure you measure every lifter.
http://www.yellowbullet.com/forum/sh...t=lifter+bores
carl hinkson is offline   Reply With Quote
Old 11-27-2015, 02:44 PM   #7
Mark Markow
you mean the isky's? I haven't had any issues with the crower.
Mark Markow
171 ss/tb
Old 11-27-2015, 06:04 PM   #8
pmrphil
Liked 348 Times in 152 Posts
I also have been using the Crower bushed lifters - can't squawk about them at all, but I only rev it to 8,000
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 11-27-2015, 06:50 PM   #9
carl hinkson
This thread I started was about Crower .903 lifters 3 sets that could not be used.
Crower 842. lifters run right at .841 to small for any GM lifter bore that is .844 which gives you .003 clearance which is to much.
Here it a good video to look over.
I deal with a lot of blocks and check and machine alot of lifters and lifters bores when I machine blocks and have seen about every lifter out there.
Old 11-28-2015, 02:14 PM   #10
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
thanks Carl.
