Liked 127 Times in 49 Posts
What is the best degree to install a cam on a 396/350 oval port motor for Stock Eliminator? Cam card says 106 but I think that is a little much.
Bobby Lundholm 3516 G/SA |
Liked 310 Times in 104 Posts
If cam was ground for that car I would start out @ 106 on 396 106 is probaly about right most BBC cams for N/A usaully are 108-110 but they are 100 + ci over 396
Mike Taylor 3601 |
Cam was ground for the car.
Liked 18 Times in 10 Posts
Is the lobe sep 110?
Lobe separation is 108
Liked 974 Times in 310 Posts
Start at 106 or whatever you think will work then advance and retard from there to see what car likes. Forget what other people say and try it yourself. Everybody doesn't have the same car and combo.Or put engine on dyno and see what engine likes.
