Old 03-30-2011, 07:47 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default What Faster?
Just wanted to know what was faster, Gas or Alky. Thanks.
TinSoldier 3215 is offline   Reply With Quote
Old 03-30-2011, 10:41 PM   #2
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: What Faster?
Gas will go through you fast and alky will get you a DWI if the cops catch you.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-31-2011, 12:06 PM   #3
Bill Baer
Well Alky will make a more midrange torque but from what we have seen on the dyno the more expensive racing gas will make about the same peak HP.
Thr real advantage to alky (naturally aspirated) is that it's less sensitive to weather changes so Alky tends to be somewhat more consistent.
Alky is also a little cheaper than the best racing gas even when you factor into it the cost of the top oil and the fact that you will use twice as much.
But alky is little higher maintenance. and IMO usually works better with fuel injection rather than a carburetor.
Old 03-31-2011, 03:37 PM   #4
SCOTT SST2871
On my 3000 lb door car with a pretty much stock engine it picked up a 1/2 second going to alcohol but with the stroker motor thats in it now its 2 tenths faster at best
scott fifield
SCOTT SST2871 is offline   Reply With Quote
